Enfield with Leaning Sidecar
February 06, 2016, 03:06:48 pm
Author Topic: seat pan for legendary's phat tail seat finished  (Read 360 times)
armando_chavez
« on: November 08, 2013, 08:09:09 pm »
so after a long time of figuring out a good seat pan, Ive finally finished it.
this seat pan will bolt right onto the frame.  it will attach at the frame seat tab right before the gas tank and at the two holes on the cross bar.  one of the holes holds up the catch can so that either has to be rigged on top of the seat pan leg or removed.
mind you, I've created this using nothing but 20 year old inginuity, craftsman ac stick welder, grinder, HF sheet metal shears, and a can of spray paint.
yes, I did have a very hard time bending the 16 gauge sheet by hand.
