WPB,FLA
35 Guests, 4 Users
wildbill, malky, mattsz, JohnDL
May 31, 2016, 05:05:05 am
Author Topic: Short Silencer  (Read 1053 times)
woodboats
  • New Zealand
Short Silencer
« on: June 22, 2008, 03:46:05 pm »
With the standard short silencer that bolts straight onto either the long or short downpipes is it always necessary to have to re-jet when installing?
If you just put them on what symptoms would you be looking for that may tell you if a re-jet is even necessary?
Cheers
PS Should have said it is for a 500.
« Last Edit: June 22, 2008, 04:58:07 pm by woodboats »
Ours: 2006 Bullet Deluxe 500
Hers: 2007 Yamaha V Star 650
His: 2007 Honda Shadow Aero 750
mrunderhill1975a
Re: Short Silencer
« Reply #1 on: June 22, 2008, 09:44:35 pm »
Do a "Plug Chop" per the Snidal manual.  If the plug is white, you are too lean and running too hot.  If the plug is caked with black char 0.5 mm thick, you are too rich.
