Ace,
My bike is year 2008 es iron barrel. One of the last old emission legislation bikes that were allowed to be registered in the EU for on-road use.
I am planning to take this bike around the Black Sea one day. That will require reliability and power to pass slower vehicles... Not to mention the right attitude in Russian / Turkish roads...
I will now replace the stock crank, by either using hitchcock crank or by buying their parts and sourcing the work locally. Also i will increase the cc from 500 to 535cc. Ace piston, cams and intake manifold will be included. FAG x-life bearings will also be installed. Proper breathing system should be restored i guess.
I'm just thinking if there is anything that i should do once the engine is in small pieces. So that once I'm done doing all this , there will be no stone that wasn't " turned" once there.... Drilling, tapping, gluing, welding.... You name it!
I hope this clears a little bit my thoughts!
Andy
