It could have been easy if I used the whole kit including kit reflector. BUT, I wanted the Tripod (I had the 2 ring kit with clips) Then I found the 7" peaked Chinese CJ outer ring (on Ebay). First thing I noticed was MY reflector was thicker/deeper than the kit base ring would permit. Then I noticed the stock base ring was a good bit deeper, but had lots of tabs for the DOT headlight & its adjustments. SO I cut those out with my Dremel Tool. I then fitted the CJ ring to the base ring, off the bike. I think I had to drill a hole at the top of the CJ ring & base ring & for a chrome locating screw & nut. I had to do a good bit of expert tweeking. I also removed the jumper wiring Pigtail inside the headlight Nacelle in order to be able to turn my lights off & on at MY discretion while I was in there & wired the pilot light & my bar end Signals.
All told I think it turned out perfectly. But for the NOVICE it may be to much of a challenge. I am an elderly guy who's been building a long time & had the confidence, I aslo did have the kit to fall back on. I was then able to recoup my investment, selling ALL left over parts on EBAY. I preferred the clean line of the CJ peaked ring to the Eyebrow add on peak. See side view pic below. Go for it if you think you can do it. That's how I learned. Cheers!
