2006 Bullet 350
May 04, 2016, 10:32:17 am
Author Topic: k & N mod completed  (Read 1050 times)
k & N mod completed
« on: June 21, 2008, 03:43:28 pm »
Just completed filter mod per previous notes...Made a big difference with the 50 style brit exhaust from our host...Carb was rejetted with 125 main, 27.5 pilot and needle moved to its lowest position...With the new filter, had to redo the air/idle mix...Think I have that right as I took it out for a 4 mile spin before adjusting the carb hot....
Took the catch can off (just a wee bit of mayo)...Both bottom hose were reamed out with a flexible wire...The Intake hose on the bottom of the catch can had nasty mayo funk in it...Think I'm done with performance on the bike as it cruises nicely at 50-65 with a bit more left in her now...Guess the plug check will tell if I have to do anything else....Pics to come later in the week after she is buffed up...Cheers and welcome any input.
