I'm sure your ES has burned your battery down in short order. If you don't have a battery charger, connect it again to a jump battery. First thing to check is if you're getting spark at the plug, sounds to me that you're not. If no spark, it can be a dozen things...get back with us. If you are getting spark, check the fuel source. You gotta do a little trouble shooting first, then update with a new post.
Good Luck.
