I should probably already know the answer to this but I don’t, so here I am.
I recently replaced my standard 5” headlamp with a 7” Lucas non sealed set up. I can not tell the difference between high and low beam; both seem to be very close in brightness. When you turn on your high beam should both filaments be illuminated? If so then I am having a problem with switching over from my old set up to my new one. Right now when I have my low beam on the lower of the two filaments lights up, on the high beam the top firmament is on but they never both turn on at the same time. I would have just checked my old set up to compare but I ended up blowing the bulb testing the output of my alternator.
Any help is greatly appreciated.
