Author Topic: Farkle Number Two Successfully Installed  (Read 5803 times)
wildbill
Reply #15 on: October 08, 2013, 01:29:04 am
here's a bit of info for other "dyi" depending on the style of the plate there may be no need to remove the front wheel on your bike. both my c5's had front plates....that said unless you have sturdy type hands!
1.run the tape down the centre of the guard
2.set up your plate position as discussed further up the thread.
3.undo and remove all 8 bolts plus the disc
4. pull the guard up and then slide a piece of flat timber between tyre and guard
5. drill the holes for the plate. the timber will hold the guard steady and stop the drill bit from puncturing the tyre.
6. remove timber -set plate in position - pull up the guard and tighten the nuts up.
Reply #16 on: October 08, 2013, 02:54:00 am
Looking good Dan!  I'm really liking the brass.   :)
I still need to get you your spare rain suit back to you too.
Reply #17 on: October 08, 2013, 03:44:23 am
It is not a cloth tape.
Cloth tapes will get snagged on the drill bit and either break the drill bit or wind up on the flutes jerking the drill bit all over the place.  Please don't use a cloth tape for locating a drilled hole.
              Cloth tape measure, not cloth masking tape. Tailors use them & my mom (as I mentioned previously) always had a couple around the house when I was a kid. She made clothes for me (& herself) in the '40s until I stopped her   ;)  "Ma! Enough! I'll buy my own shirts now"!
DanKearney
Reply #18 on: October 08, 2013, 04:29:47 am
No worries Scottie.  If the weather is good this coming weekend, maybe we'll meet up for a ride.
Cheers,
Dan K.
Reply #19 on: October 08, 2013, 05:34:32 am
My mom probably lost over a dozen of those cloth measuring tapes from her sewing supplies before she finely figured out her little boy was 'borrowing' them for various projects.
After she put her foot down forbidding my borrowing and made a lasting impression on me
the mystery of the disappearing tapes was solved. :(
The main reason I mentioned that the blue painters tape was paper is because the way I read some of the posts, others were talking like it was cloth.
heloego
  • USA '12 C5, '06 ElectraX
Reply #20 on: October 09, 2013, 03:46:46 am
Sheet Metal Layout 101.  :)
Excellent procedure for those who haven't done it yet. Protect the Guard and the tire!
'12 C5 Classic
