I'm wondering if anyone can shed some light on a situation I'm experiencing.
I changed my oil and filter recently, and measured the amount of oil I removed. I soaked the new filter in fresh oil, installed it, and refilled with the same amount of new oil. It ended up a little low, as I might expect since there are "losses" from the old filter, residue left in my drain pan, etc. I added a few more ounces, and got it where I thought it should be, warmed it up and ran it around the block for 10 or so minutes, then parked it and let it rest for a bit. I topped it up a bit more to where I'm used to seeing it, at about the lower "bar" on the sight-glass.
I took off on a trip the next day, and after about 100 miles, I parked the bike for a meal and found that the sight-glass was "blank" - I had to tilt the bike just a little bit before the oil showed, regardless of how I positioned the bike on what I thought was a level surface. I couldn't see any signs of a leak or burning of oil.
I had no oil with me, so I started it up and planned to ride it another 20 miles to a proper town that might sell some moto oil. The bike ran fine, but I did hear a clatter which I've never heard before - not evident at idle, but a louder ticking that started at about (I'm guessing) 2000 rpm. It worried me. I stopped at a motorsports shop, and in the lot, right after I shut the engine off, the level was perfectly fine!
I went in and discussed it with the owner, but typically, he didn't have any experience with these engines. I bought the oil anyway, to carry with me.
I rode down the block, only about 1/4 mile, topped up my fuel tank, and looked at the oil again - nothing in the glass! WTF? I ended up adding almost 7 ounces before the oil showed in the glass again. I started the bike up, and watched as the level rose up above the top of the glass. I shut it off again and let it rest - it never did come back down, but tilting to left just a little bit showed a top level in the glass, so I'm hoping it wasn't too full. It still makes that new tick at the mid to high-range rpms... it's very difficult for me to hear since I've reinstalled my windscreen, and the usual helmet noise makes it impossible to hear anything at all once I'm up to speed.
Now, 120 miles and a day later, the bike is parked on the center stand in my parent's garage, looking perfectly level, and the sight-glass is
empty again - it takes quite a tilt to the right to show the oil level. The oil drain plug and oil screen cover are clean and dry, with no other signs of a leak anywhere, and not a drop on the floor. Nothing like this has happened the other times the oil and filter were changed.
I'm very confused. Anybody run into this kind of inconsistency in reading oil level?
