Deejay,
Did you use the stock Indian gasket dry, or did you use a sealant?
Is the fact that the composite gasket "melted" indicate that it is supposed to be self-sealing? or does your engine run extremely hot? or are the specs on the gasket not up to the heat range of a big single?
"Stonger studs" are you referring to the removable square end studs available from CMW? I already have the hardened washers and find that they get stuck in the head too, as the mating surface in the head is concave and the washers collapse into this depression and are difficult to remove. One fellow on the Yahoo site went to the trouble of flattening the seat for the washer to set square without distortion.
My only reservation about the purchase of the stronger studs is the strength of the case into which they screw.
I have a stock gasket in my workroom. I think I will install that next with brush-on copper gasket sealer. And I will be a little lighter with the torque wrench than the full 285 inch lbs. (I tighten it up in several 50# "lifts" anyway.)
Thanks for the details on the composite gasket experience. I was wondering why I was taking my time getting around to ordering it. Kharma , I guess..
-Jesse, my head's on tight, it's the gasket that leaks...
