Does the latest version of power commander V connect to oxygen sensor to get feedback from exhaust to adjust AFR ?
Or the maps are based exclusively on the throttle position and engine RPM ?
No Singh. The latest version does not connect to the stock narrow band O2 sensor, it also has a "Fooler" that plugs into the stock harness. It basically just "Tricks" the ECU into thinking it is there. Then the MAPs , fuel and ignition, are created on a Dyno, with a tailpipe sniffer that reads AFR's. The AFR numbers are changed by the operator of the Dyno, .... Usually between 13.2 :1 to 13.7 :1 based on the results he sees as far as HP and torque. He can also advance or retard the timing based on the information he is getting from the Dyno. All of this is done across the throttle and RPM range.
As you know, the stock O2 sensor is more switch like. And does it's best to keep the AFR at stoichiometric, which is 14.7:1 . This is a good mixture for emisions purposes , by not for power. So as we make modest intake and exhaust changes on our bikes, that the stock ECU can "Cope with" . They may help some.... BUT the O2 sensor and ECU are still trying to keep that 14.7: 1 AFR. With that in mind when a change is made to the intake and exhaust, one should be careful about how modest that change is. Because if it's not THAT modest, you may at least negatively effect performance , or you could go dangerously lean in some area's of the RPM Range.
Also, the ECU is NOT always in closed loop, with the O2 sensor keeping the mix at Stoich. It's in closed loop at Idle, after the O2 sensor heats up. It's comes out of closed loop at maybe 20-30 % throttle opening. So on hard acceleration..... your not in closed loop. Generally, you are in closed loop when cruising. When your out of closed loop in those situations... the ECU is relying on the inputs from the MAP, TPS, Temp sensors etc. And look up tables in the ECU to compensate. If one of those look up tables that the ECU can choose from doesn't match, or is not programmed into the ECU for the change you have made........ It don't work out too well.
Hi,
The old version of the PC5 does allow for increasing the rev limit if you upgrade the firmware to the new version. That is what I did. Regards
Interesting Roland, what is the update ? Do they add a wire to the Ignition Coil ?
