I am wondering if the top cap is not reverse-threads in the upper-fork of C5.
GHG or JVS or anyone who has C5 can correct me if I do not understand your motorcycle fork system. I assume you use top-cap to unscrew the upper-fork.
Do you turn the top-cap CLOCKWISE
when looking down from above to unscrew the upper-fork ? That will be consistent with upper-fork having regular threads.
If upper-fork has regular threads, it will LOOSEN out of nacelle ANTICLOCKWISE
when looking up from below or CLOCKWISE
looking down from above.If the top-cap has reverse-threads, then turning it CLOCKWISE
looking down from above will LOOSEN the top cap itself, leaving the upper-fork stuck in nacelle.
Enquiring minds want to know
EDIT - GHG you are typing and me typing at the same time trying to figure this out what is going on !
