1Misty Mornin
17 Guests, 4 Users
hpwaco, dginfw, alladinko, heloego
February 12, 2016, 08:37:09 pm
Author Topic: UCE Throttle Body, ECU and Programmer  (Read 4356 times)
Re: UCE Throttle Body, ECU and Programmer
« Reply #15 on: September 21, 2013, 06:50:05 pm »
Hooking up an aftermarket TB to my bike will not be a problem.  Alex (my coworker, friend, engine guy, Subaru Turbo Guru) and I are both talented custom fabricators.  He's very good with aluminum TIG and I can cut, bend, hammer and weld steel all day long.  I guess what really grabs my attention with the ecotron set up is that it is EVERYTHING you need except plumbing for $700!  I'll probably get the motor running without the turbo first with the auto tune feature to get a good baseline.  Then install the turbo and map the ECU by crunching numbers according to the original baseline.  Holy shit I'm excited!
   There you go .  Go, have fun and put some shove in that motor !  8)   ;)
« Reply #16 on: September 21, 2013, 07:47:17 pm »
The plans right now are to run 8:1 - 9.5:1 pistons, start at 5psi of boost and hopefully settle in around 8-10psi of boost.  GHG or Ace Do you know if I can offset the camshaft/s when assembling the motor to change timing/duration in order to run/redline say 8000 RPMs?  I plan on balancing the crankshaft to 10,000 RPMs.  I'm also considering using the 1 piece alloy cylinders for the interceptors, I emailed Hitchcocks and they said it bolts up to the 700 case but no one has done it as if yet.
« Reply #17 on: September 21, 2013, 08:11:49 pm »
You can rephase the cams, but there's only just so much that you can do with just that.
Generally, boosted engines need more lift and larger than normal exhaust valve, along with the rephased cam timing.
It can all be done.
« Reply #18 on: September 21, 2013, 08:14:20 pm »
I already planned on doing a full port and valve job.   ;)   Now check THIS out.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290778026778&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
 ;D ;D ;D
« Reply #19 on: September 21, 2013, 09:55:30 pm »
 Ummmmmmm ?....... Now you got me thinking.
http://www.ecotrons.com/Small_Engine_RHB31_VZ21_turbocharger.html
« Reply #20 on: September 21, 2013, 10:50:34 pm »
I see some rods poking out holes in cases.......
« Reply #21 on: September 22, 2013, 01:00:55 am »
 We'll have to search the threads here but I seem to remember someone mentioning the bottom end of the UCE being engineered and built for 60-65 horsepower.
« Reply #22 on: September 22, 2013, 05:34:02 am »
"Free shipping for the turbo if you buy an EFI kit together!"   8)
« Reply #23 on: September 22, 2013, 06:29:21 am »
The exhaust pulses from a low-revving single are timed fairly wide apart, which is not ideal for spooling up a turbo. I think a supercharger would be a better application.
The small turbo should work okay with the twin, though.
Bottom end strength of the twin may come into question when stressed to that level.
« Reply #24 on: September 22, 2013, 08:57:41 am »
Now when you guys say "weak bottom" end I think of crappy rods that like to stretch and break.  Am I missing something here?  Have crankshafts exploded out of these cases?  Like I said I plan on having the crankshaft balanced to 10,000 RPMs and I'm hoping to put some Carrillo rods in there.  Is this not good enough?
« Reply #25 on: September 22, 2013, 10:42:41 am »
  Yeah, he..he..he.. I might be able to knock off two birds with one stone. Supercharging on the cheap with NOS !!.........
http://www.youtube.com/watch?v=dyR0U_fYtwY
« Reply #26 on: September 22, 2013, 11:45:41 am »
I thought about NOS, but it has it's down falls too.  Such as you only get the extra HP when you use it, you have to make a special trip to the hot rod shop when you need to refill.  I want to turbo.  Mainly because it's never been done before and I want to be the 1st to do it.  People say it can't be done, I call BS.  Sure, I'm probably going to spend $5000 on just the motor, but it's going to be so worth it!  I'll have the ONLY turbo Enfield twin in the world.  How effing cool is that?!  I'm going to make this happen, even if it means hours upon hundreds of hours of research,  custom fabrication and machining, I want to make this happen.
« Reply #27 on: September 22, 2013, 12:44:30 pm »
 +1..  Extremely Effing cool !.. Turbo's more practical for the street. Plus, you don't have a trunk to store all those bottles. :-\  I've seen them rigged up and hanging on a bike. But it looks like crap.  The sport bike guys, hide 'em under the rear cowl ?  But..... I doubt that would work for you.
1 Thump
« Reply #28 on: September 22, 2013, 12:49:19 pm »
Here you go : http://www.xbhp.com/talkies/thumpers-two-stroke-exotics/17262-presenting-worlds-first-supercharged-enfield-rr700-prostreet.html
The owner of this bike posted it here on this forum a while back. I dont know how it turned out in the long run but you might want to consider reaching out to him......
« Reply #29 on: September 22, 2013, 01:08:30 pm »
  Pretty cool...........
