Installing the Duckbill
19 Guests, 2 Users
Quiqueaus, PerazziMx14
May 27, 2016, 05:27:05 am
Author Topic: Enfield Maintenance List..  (Read 2002 times)
Afro Samurai
  • Afro Samurai
« on: September 19, 2013, 12:36:55 pm »
just a maintenance list i came up with.. to print out..
excel file..
has several tabs..the original list.. then a milage list.. then a reordered list where i reordered the listing into sub tasks in the order i felt was more logical to  me.. and with my milage intervals already calculated out..
And to clarify...its not some fancy whiz bang sheet...so nothing is formulated...although I will make some formulas where you can have it auto calc intervals etc....just something I started today at lunch...will make it more intelligent and repost...if you have any suggestions..let me know...or by all means improve on it and share...
feel free to modify as you like...
« Last Edit: September 19, 2013, 03:05:10 pm by Afro Samurai »
mrunderhill1975a
Re: Enfield Maintenance List..
« Reply #1 on: September 19, 2013, 03:22:52 pm »
I did not see any reference to the points cleaning or replacement, did I miss it?
Afro Samurai
  • Afro Samurai
« Reply #2 on: September 19, 2013, 04:37:10 pm »
I will check...I think on the original tab I have jpegs of the maint from the manual....but I think its from owners manual of newer bikes...I will be sure to include that item...
Voyager AL
« Reply #3 on: September 19, 2013, 07:47:16 pm »
I cant open XL docs. Can ya JPEG it?
Afro Samurai
  • Afro Samurai
« Reply #4 on: September 19, 2013, 08:20:19 pm »
Will do in the AM...when get back to work...will also get a pdf going...
Will also do an empty version for those who wish to print and write in their own intervals.
Afro Samurai
  • Afro Samurai
« Reply #5 on: September 20, 2013, 05:46:49 am »
here is a pdf of the maintenance tab in the excell ...
just a beginning.. to give some idea of the layout..
jpeg turned out so small couldnt see anything...hope you can view PDF.. i will still do a jpeg.. just need to figure some settings to get the resolution.. or just do jpeg of each section...
a work in progress.. have since added several linked and calculated cells for custom intervals .. and beginning milage inputs for new owners... im gonna go nuts on it.. make it slick.. but still be able to do a simple print of a blank sheet or prefilled in sheet so you can store with the bike..
also has tabs with shots from manuals on torq values (which will be tabulated with a correction factor that you can customize to calc your own values)... specs, exploded views, parts lists.. etc.. all in excell...
Afro Samurai
  • Afro Samurai
« Reply #6 on: September 20, 2013, 05:53:49 am »
got it...
« Reply #7 on: September 20, 2013, 04:57:00 pm »
I don't see primary chain or tranny listed either. Where is this doc. from?
Afro Samurai
  • Afro Samurai
« Reply #8 on: September 20, 2013, 05:35:41 pm »
Nfield gear sells a super factory manual...and online I found a bullet owners manual....good catch...will be sure to include that line item..
Super factory manual has prim chain in the list...the owners manual didnt...images from owners man are on the original tab in excell file...I will be fixing all that stuff..
« Last Edit: September 20, 2013, 05:38:08 pm by Afro Samurai »
rvcycleguy
« Reply #9 on: September 20, 2013, 05:42:26 pm »
I did not see a reference to adjusting or checking the valve clearance?
Afro Samurai
  • Afro Samurai
« Reply #10 on: September 20, 2013, 06:28:42 pm »
I noticed that also...will get it in the list...
Afro Samurai
  • Afro Samurai
« Reply #11 on: September 23, 2013, 11:46:40 am »
just an update...
got a number of items added to the list that was missing..
also adding a few additional tabs.. that will cover a number of additional topics often covered in the chats.. ..
will post these updates this week..
Afro Samurai
  • Afro Samurai
Re: Enfield Maintenance List.. Updated Excel
« Reply #12 on: September 27, 2013, 11:17:32 am »
still working on some of the entries..
here is an updated version..
let me know if I am missing any other inputs..
Maintenance Sched Tab is the main item.. i am adding additional useful info in the other tabs.. and planning on linking to some topics on this site.. but again.. there will be a plain blank version also..
hmmm.. file size is too large.. will see if i can reduce the size of the imbedded jpegs... but untill then.. here is the maintenance sched tab..
Afro Samurai
  • Afro Samurai
« Reply #13 on: October 01, 2013, 10:59:24 am »
almost done..
will be breaking up the file to a smaller size.. may be separating the excell out to several differnt files... cause i have several tabs with some usefull info... it all comes down to the file size... its pretty massive..
« Reply #14 on: October 01, 2013, 11:17:09 am »
Don't forget to add the Mailbox and Soccer Mom repellers.  You've all read what happens when you leave them at home.
