Hello everybody :)
20 Guests, 3 Users
ace.cafe, dginfw, hpwaco
February 12, 2016, 08:47:41 pm
Author Topic: has anyone tried this Tri bar halogen light  (Read 2065 times)
ROVERMAN
Re: has anyone tried this Tri bar halogen light
« Reply #15 on: October 01, 2013, 10:29:06 am »
Any movement on this front? Singhchicago maybe?
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
« Reply #16 on: October 01, 2013, 01:25:16 pm »
Not meaning to offend anyone. However I would not buy THAT headlight. I would get one with the full reflector & pilot bulb. It WILL throw more light downwards on the road, whereas the directional unit cuts off  the lower part of the beam, making the pavement less visible - You could hit a turtle!  The full reflector tripods are available on Ebay all the time. I believe they work, & look better.
Best Wishes, Craig McClure
ROVERMAN
« Reply #17 on: October 01, 2013, 01:48:45 pm »
Cheers Craig. Still be interested if Singh Chicago made it work.
Robert
majbjd
« Reply #18 on: October 02, 2013, 01:29:17 am »
The best headlight I ever put on a bike is the Harley dual bulb unit. Low beam is broad and has excellent distance. The high beam is a separate 35 watt bulb in a spotlight inset inside the headlight. The low beam stays on when the high beam is on. Total draw is 90 watts in high beam mode. A dedicated relay fed directly from the battery is the way to rig it. The question is can the system support the 90 watt draw.
Roeland
« Reply #19 on: October 02, 2013, 11:23:03 am »
I believe it can at high speed or short distances at lower speeds (when needed). I'm running two 55 watt H3 spot lights in conjunction with the 55 watt headlight - that's 165 watts in total.
Singh_Chicago
« Reply #20 on: October 07, 2013, 08:23:44 pm »
Here are the results, it has enough light.... enjoy
http://www.youtube.com/watch?v=v38uVZQQ1kA
ROVERMAN
« Reply #21 on: October 08, 2013, 08:13:53 am »
 Thanks Singh, thats what i was looking for. I think a blue pilot lamp would look cool as opposed to the yellow hue.
Roverman.
crush02342002
« Reply #22 on: October 09, 2013, 07:12:48 pm »
not bad..high beam looks a lot better than the stock lamp
