Author Topic: Lower brake pedal now.  (Read 1464 times)
potboiler
on: September 12, 2013, 10:30:14 am
I did'nt like the way the foot brake contacts the exhaust pipe and also that it was higher than the footrest and obstructed my foot. I've now fitted a simple stop behind the brake- spindle-arm on the left side of the bike. It's just a short piece of copper water pipe bolted onto the redundant boss on the frame (see photos). My foot can now sit comfortably on the footrest.
Reply #1 on: September 12, 2013, 01:27:10 pm
        I can't understand exactly what this mod does.
         My pedal also was too high & in my way & didn't feel right when I first got my '08 Classic. I used the bike's own up/down pedal adjuster mechanism to move the pedal down to that perfect position.
D the D
Reply #2 on: September 12, 2013, 02:10:00 pm
+1.  The bikes come with adjusters.  Someone's invented a fix where there was no problem.
1975 XLCH
Reply #3 on: September 12, 2013, 05:39:19 pm
There is a bolt below the brake light switch that can be adjusted to raise and lower the brake pedal. Works great.
