Author Topic: First Oil Change - Is this normal?  (Read 7310 times)
DanKearney
on: September 01, 2013, 12:51:16 am
Howdy All,
I hit 307 miles on the way home from work a few days ago.  I did the first oil change this morning.  Not real happy about the amount of swarf that was attached to the drain plug magnet.  Even less happy about the amount of metal stuck to the oil strainer.
Since this is my first Enfield, please chime in with your opinons.
Cheers,
Dan K.
Reply #1 on: September 01, 2013, 01:29:02 am
Looks pretty normal for the first oil change.  That's why it is so important that it gets done.
Your next scheduled change will have a LOT fewer pieces of metal and by the time you reach your third change you won't find any actual chips.  You will continue to find some very fine particles on the two magnets though.
Have a good'un. :)
JVS
  • I love chicken
Reply #2 on: September 01, 2013, 02:54:18 am
Ah that is the usual case of UCE Enfield diarrhea on the first nappy change.
As Arizoni has said, over the next few oil+oil filter changes, you'll have very few pieces of metal..even nothing..but you'll still get metal fillings on the magnets.
Enjoy your RE  ;D
DanKearney
Reply #3 on: September 01, 2013, 05:30:34 am
Cheers guys.  Thanks for the reassuring info.  If that stuff came out of my Ural, I wouldn't think twice, but I've got zero Enfield knowledge.
Dan K.
Reply #4 on: September 01, 2013, 08:24:45 am
Lots of dealers sell both Urals and Enfields, there are lots of parallels.  What you saw was normal, and that's what the magnet and screen are for :)
BadDP
Reply #5 on: September 01, 2013, 01:09:24 pm
Most certainly cleaner then my first oil change.
Catbird
Reply #6 on: September 01, 2013, 02:04:14 pm
...I hit 307 miles on the way home from work a few days ago.  I did the first oil change this morning.  Not real happy about the amount of swarf that was attached to the drain plug magnet.  Even less happy about the amount of metal stuck to the oil strainer...
Dan -
I am also new to Royal Enfield motorcycles.  Mine will probably reach the 300 mile mark next week. Since I have never performed an oil change on an RE, I found your pic SHOCKING to say the least.  If I had found those chunks, I probably would have loaded up the bike on my trailer and toted it 80 miles to my dealer for surgery. Thank goodness we have some great members on this forum with a lot of knowledge that they freely share.
1972 Honda CB350 twin - sold
1976 Honda GL1000 Goldwing - sold
1996 BMW R1100RT - sold
2005 BMW R1200RT - sold
2011 Vespa GTS 300
2013 Royal Enfield C5 Military
2014 Honda CTX700N DCT
2014 Honda CB1100
Reply #7 on: September 01, 2013, 02:26:03 pm
Almost every member here posts a pic of the magnets/drain plug on their first oil change, and let me tell you, I have seen some pretty nasty ones!  But it's the nature of the beast, every brand new motor will show signs of metal shavings, chunks,  burrs, fine metal particles, and silicone in the first few oil changes.  The reason why a lot of people on here freak out is because it's new to them.  Most new vehicle manufacturers break in their motors before they are ever installed in the vehicle, which is why you never see anything like this in most new cars/bikes.  They have already done the break in procedure and have removed all that nastiness with the first couple oil changes at the factory before you get to see it.  It just adds to the charm of an RE IMO.  But this is also how it was in the days of old.  Before the 70's, when you bought a new car, you had to do the same kind of procedure.  Take it very easy for the first 500 miles, change the oil in a few hundred miles, then 500, then 1000, then start abusing it.  ;D  Modern computerized factories have taken this joy away from the new consumer.
Gypsyjon
Reply #8 on: September 01, 2013, 03:13:02 pm
When I did my first oil change I had the metal plus what looked like part of the assemblers T shirt.
NorEaster
Reply #9 on: September 20, 2013, 02:21:29 am
Just gave the 2014 C5 Classic its first oil change. It was actually quite clean. Some minor flecks in the strainer and drain plug magnet.
gremlin
Reply #10 on: September 20, 2013, 02:38:45 am
Yes, that is normal for the first oil change.
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
squire
Reply #11 on: September 20, 2013, 05:02:26 am
Looks pretty good actually, I had quite a few bits of blue paper towel in mine. I had a new 05 Ural that was as bad or worse, as an earlier poster stated, there are a lot of similarities between the two brands.
wildbill
Reply #12 on: September 20, 2013, 08:16:36 am
when i did the first oil change on my B5 - it had a totally clean filter plus a very small amount of filing on the magnets. happy with that i mention this to the dealer who i purchased it from.
his quick reply. " i removed all that rubbish from the filter screen whist doing the delivery service for you."
Reply #13 on: September 20, 2013, 12:25:26 pm
Keep that dealer, wildbill!
lemeng15
Reply #14 on: October 24, 2013, 09:52:50 am
normal. mine is as bad. the mechanic also told me that its normal for first oil change
