As above with the Bosch coil, wire connectors, grounds, all bolts, Mikuni flatslide carb, Iridium plug, replaced old throttle/brake/clutch cables with non-India ones, LED bulbs, Amsoil in everything but the forks, Torco Fork Oil in the forks, Tsubaki O-ring chain, GM waterproof electrical connectors in place of the open ones, Crankvent breather mod, probably other minor stuff I can't think of.
