Kiwichick and her Electra
February 09, 2016, 12:05:31 am
Author Topic: Bouncing front end  (Read 1643 times)
boggy
  • Karma Ultra: 7
Bouncing front end
« on: August 24, 2013, 07:39:14 pm »
I get more of a bounce, than the usual vibes over 25mph.  Just started happening. My new K70s/3.5 were really low all early Summer and I just set them to 24F/28R.  I need to get a proper tire gauge to double check as I don't trust the gas station gauge or my Cruz tool gauge so that is my first order of business.  However I also just fixed a leaking fork oil drain bolt and both sides have fresh ATF-F (I had it in there before with no bounce).
Any ideas on tires vs forks?  I put in 200ml as I did before.  2007 AVL.
Thanks. Boggy
PS if you have a tire gauge you trust let me know what kind.
2007 AVL
2006 DRZ400SM
greenie
Re: Bouncing front end
« Reply #1 on: August 24, 2013, 10:22:24 pm »
FWIW i'm using an older craftsman digital gauge and i do trust it.
did you possibly throw a wheel weight?  good luck
95 ural tourist w/ 98 motor (650)
06 electra
Buckeroo
« Reply #2 on: August 25, 2013, 09:55:05 am »
Sounds like your front wheel is out of balance.
Classic Frame and AVL motor
Electric Start
Electronic Ignition
5 speed
CV Carb
« Reply #3 on: August 25, 2013, 11:36:47 am »
+1  Take them off and get them balanced.  My Triumph dealer mechs will do it for a 12 pack of Mountain Dew and the price of any spoke weights they use.  Use the spoke weights, not the stick-ons.  Stick-ons tend to get thrown to the wind.
Get a dial gauge or digital gauge from the autoparts store.  Any but the cheapest is better than the gauges on the gas station pumps that people throw to the ground all the time.
Accuracy of + or - one lb doesn't really matter.  Once you have a reading that runs well for you, say 24/28 or 26/30, just use the same gauge all the time.  You want to maintain the same setting and eliminate the variable accuracy of using random gauges.
boggy
  • Karma Ultra: 7
« Reply #4 on: August 28, 2013, 09:35:36 am »
OK - sounds like the consensus is balance issue.  I definitely did not lose a front weight so I'm not sure how it went out of balance. However, I did so much fork work this Spring/Summer I may have been focusing on the them during my rides (plus there is hardly a smooth road around here).
Just wanted to double check this wasn't a tell tale sign of tire pressure/fork oil issues. Thanks for the feedback.
Boggy
2007 AVL
2006 DRZ400SM
« Reply #5 on: August 28, 2013, 09:49:41 am »
If you hit any big pot holes you may have bent your wheel which would make it feel out of balance.
DanKearney
« Reply #6 on: August 28, 2013, 01:57:59 pm »
If you're going to go for a re-balance, I suggest you consider using Dynabeads instead of traditional wheel weights.  I've found them to work much better than weights on all three of my bikes.  2oz in each tube seems to work best.
Cheers,
Dan K.
KB8ANY
« Reply #7 on: August 29, 2013, 01:23:06 pm »
I had the same problem early on, and in addition a "clank" when the fork would drop off of something (like the lip of a pothole) without first being compressed.
Also, on my bike, the 200ml did not give the level called out in the shop manual.  The shop manual calls out sticking a 1/4 inch rod down into the fork, with a resulting level of 370mm to 380mm.  With 200ml the level was too low.
I cured both by putting in 240 - 250 ml.
I also get a better ride with ordinary 10W-30 oil, also called out by the shop manual.
Good luck.
Paul
classicrider
« Reply #8 on: August 30, 2013, 05:00:16 am »
Seriously i can't work out the logic in using ATF-F in front forks.It's great in certain bike clutch's,but front forks need the slipperiest lube you can buy.It's all about reducing friction on seals and bushes.
Using an oil with high friction will only create bounce by resisting movement until a point is reached,and this energy will release all of a sudden.Hard on the wrists.My bet is this is the cause.
« Reply #9 on: August 30, 2013, 09:12:44 am »
"Stiction"
ATF is the snake oil of choice for bikers.  Fork Oil is designed to reduce "Stiction", ATF is designed to, uh, run in an automatic transmission.
boggy
  • Karma Ultra: 7
« Reply #10 on: August 30, 2013, 09:19:06 am »
I had the same problem early on...
That is very interesting. I was under the impression 200mm was tip top tight but I didn't check.  OK... very good to know.
Seriously i can't work out the logic in using ATF-F in front forks.It's great in certain bike clutch's,but front forks need the slipperiest lube you can buy. My bet is this is the cause.
OK.  Well this is a VERY easy thing for me to try.  I did just put the ATF in this Spring so you may be on to something.  It seemed like guy have been using ATF in their forks forever so I figured "old bike design - old bike logic," but maybe that's not serving me best in this case.
I've heard people use 5w, 10w, and 15w fork oil so maybe I'll start in the middle at 10.
Haha.  Awesome.
Ok... thanks guys.  Good stuff.  Appreciate the info.
Boggy
2007 AVL
2006 DRZ400SM
« Reply #11 on: August 30, 2013, 09:27:08 am »
Oh, and some people won't admit this, but they use ATF 'cause they're just too cheap to buy the right stuff.
KB8ANY
« Reply #12 on: August 30, 2013, 10:01:12 am »
Haha.  Awesome.
Boggy:
I only offer the 240ml trick because that's what I found on my bike.  I have been around long enough to not be surprised when I find that components don't match up with manufacturing runs.  A 1/4" dowel from Ace Hardware is an inexpensive checking tool.
Good luck.
Paul
Boggy
« Reply #13 on: August 30, 2013, 04:10:56 pm »
The book actually calls for 265 ml of oil in your forks. the 200 ml or so comes from never knowing how much you got out when you drained the sludge. If you have already changed the oil with something that will actually run out, (which you did), that could have washed the sludge away, and now you can actually change all the oil. But gotta go with the fork oil argment. it is actually made for forks! Some old wives tales never die! As for causing the shaking, my bet would be that your tire is out of round for setting so long. Try about 40psi in it, ride it awhile, and see if that will round it out again. Also when you reset your pressure again, use less air, like about 18 psi Front and 24 rear. You'll have a lot smoother ride and have the air pressure down to the recommendations.
boggy
  • Karma Ultra: 7
« Reply #14 on: August 31, 2013, 12:34:22 pm »
Where the heck did I get 200ml from?  OK, I should definitely try putting in the correct amount. I don't have an AVL shop manual... just the Snidal which I'm not 100% sure covers the AVL's fork-fill limit.  I'll also get some proper fork oil.  Changing the oil is fast although you'd be surprised how hard it is to find crush washers around here.  Only the Ducati-Triumph shop had what I needed and they were 3 bucks per for "Yamaha" brand washers.  Glad now I bought extras.
I'll definitely try that air pressure trick.  I never thought about it but yeah... it sat for a few months this Spring while the weather went from cold and rainy to way to effing hot to gear up.
Thanks.
2007 AVL
2006 DRZ400SM
