Yesterday when mounting my aftermarket silencer, I took off the header pipe and noticed that it wasn't seated properly on the engine exhaust hole. (this happened when I removed the header pipe for hot-pipe removal- apparently I didn't mount it back on well enough). For the past week or so I've been getting significant exhaust blow-by out and around the header pipe. Didn't know until now. My new gasket is fairly burnt up, and the steel skeleton of the gasket is visible in many portions of it. I mounted it back up, with a bunch of grease to help seat it in place, but i'm sure it's still not 'sealed'.
I'm at work now (via my bike), which is 55 miles from home. I'm also going straight on a weekend visit from here at 5 PM to DC (30 miles away). I read a post or two on Liquid Gasket (Black Hi-Temp RTC) and I know it has to set up a while before riding.
I plan to get some of that RTC and try and seal the leak once I get to my friend's place tonight, but in the meantime, is it super harmful to run it with the header leak? I'm jetted up significantly, and although still lean at WOT, it seems pretty much fine at other ranges.
Also, will I be able to find a replacement gasket anywhere, or is this an Enfield-only size part?
Thanks very much for any help or advice. I plan to pick-up anything I need to fix it over lunch or right after work.
Cheers,
Chuck
