Firstly hello all on here its my first post.
Been after one for ages here in Blighty and after a look on Ebay i won one for 700 quid. Its a runner, has an 930 Amal carb and started after 7 kicks after being stood for a year. I need a hand with a few things so any info from you lot would be greatly appreciated. I have no idea how much oil n grease to put where in what quantities. I need a wiring diagram that is simple as my Bullet has been played with in the electrics department, it has had the indicators removed, the switch gear has been removed and the horn is operated by one of those chrome old style British ones. Headlight is still operated by the switch on the headlight housing (but flickers and gives you a belt when you use it
Thanks
