Dual plug is one thing: two plugs and they both fire. This helps in India where quality gasoline may be available and also adds some redundancy in case one ignition system fails.
Some engines use a 'wasted spark' method. In a four stroke engine you only need a spark every other revolution, at the top of the compression stroke. However, if you just fire every time the piston comes up one spark is 'wasted' on the exhaust stroke. It does nothing but makes the spark plug firing simpler. Is this a compression stroke? Should I fire? Who care! Just fire away.
When spark was created with a mechanical switch, i.e. points, whatever drove the points was gear driven off the engine and the spark was in synch with compression. With modern electronic ignition the position is read by a passing magnet on the crank, but that sensor has no sense if this is a compression or exhaust stroke. Rather than build a system to determine that, just fire every time.
All that said, I'm not sure if our engines are wasted spark or not, but Harley's are I believe. The point it, in a wasted spark system the plug fires on every revolution.
