Author Topic: PAV Plug Bung - too long?  (Read 1400 times)
Superchuck
on: August 02, 2013, 08:32:51 pm
I'm About to do the PAV removal mod and I found a M16x1.5 threaded bung at Advance Auto parts.  It seems just about perfect for the job, but it has a non-threaded extension which protrudes further into the engine.  From the tip, there's about a half inch of non-threaded length, then the half inch of threading, then the hex head.
Will this non-threaded protrusion reduce the air-flow capacity of my engine?  Will it interfere with internal moving parts?  If so, should I just cut off the protrusion with a sawzall or dremel, and file off any loose shavings?  I'd rather not modify it if it won't cause problems, but willing to make the change if it'll help out.
Thanks!
Chuck
ERC
Reply #1 on: August 02, 2013, 10:40:30 pm
Cut it off.  ERC
Superchuck
Reply #2 on: August 03, 2013, 03:39:19 pm
Ok thanks, better safe than sorry I guess  :-\
