Scottie,
Thanks for your reply, re-soldering has been a consideration, but the only soldering I've ever done is plumbing and small wiring. I've never soldered items subjected to the extreme tension force of control cables.
Secondly, I found that my clutch cable is an optional heavy duty affair that I got from ?Vince?, I don't recall. It has a monster necked bulb on the transmission end that I had to trim to fit into the cage in the tranny. I must be getting old because I, just now, recall changing out part of the clutch cable connection innards to relieve stress on the cable end. (When did I do that?)
Anyway, the heavy duty clutch cable has a thicker housing/shielding than a stock cable (I found a stock one in my part bin to compare) and an added "wear" housing section where it runs through the casquette. All of this contributes to the lack of flexibility of the heavy duty cable.
I removed the extra layer, which also had a heat crimped label, which, in turn, peeled off part of the inner housing as it was cut free. Oh joy. I will now have to affect a repair on the housing with heat shrink tubing or...
Without this extra "wear" sleeve, the cable now bends sufficiently to attach to the lever. I must really be getting old because the last time I rode this girl it was a real tussle pulling in the clutch lever. Not sticky, nor rough, just hard. My Moto Guzzi clutch is a not as hard but then, too, like me, it's an older model
I shall continue on now. Thanks for your advice. If you can get back to me with any pointers on soldering the stressed joint of a cable end, I would appreciate that.
Thanks,
Jesse
