Author Topic: thread direction engine sprocket bolt  (Read 1339 times)
AwL
on: July 30, 2013, 04:12:52 am
The engine sprocket bolt on my 2009 G5 is a "right hand thread" (clockwise to tighten).  I am under the impression that on later model UCE engines this was changed to "left hand thread" (counter clockwise to tighten).  If this is true when was the change from RH to LH thread for engine sprocket bolt made?  Can one tell by the engine number?  Did they also make this change for the nyloc nut on the clutch shaft or is it RH thread on all UCE engines?  Of course i could be totally wrong about this, as is often the case - just ask my wife!
   Story i heard somewhere is that the bolt/shaft thread direction was changed as the RH threaded bolts holding sprocket on could come loose, as mine did.  Fortunately when i heard a sound like squirrels had stored nuts inside the LH cover i took it off and found the bolt rolling around before it did any damage, and replaced bolt using blue loctite.
Reply #1 on: July 30, 2013, 04:10:35 pm
I think the sprocket is still the same.  I had heard the bolt holding the clutch basket to the crank was changed to reverse thread.
GSS
Reply #2 on: July 31, 2013, 01:53:53 am
+1
2022 Continental GT 650 Dux Deluxe
2019 Himalayan Snow
2019 Interceptor 650 - Chrome...off the first boat!
Previous REs:
2021 Meteor 350 Supernova Blue
2014 Continental GT 535 - Red...lowest VIN off the first boat!
2010 Classic 500 - Teal Chrome
shamelin
Reply #3 on: July 31, 2013, 03:45:35 am
My 2011 B5 front sprocket bolt is right handed, although you would have thought it was reverse threaded with as much force as it required to take the damn thing off.
