Installing the Duckbill
May 30, 2016, 09:35:29 am
Author Topic: Dirty Oil Screen?  (Read 514 times)
Catbird
Dirty Oil Screen?
« on: July 28, 2013, 06:21:56 pm »
I have a new Royal Enfield Military.  I have read the literature and watched the youtube videos, however I don't recall any advice for the preferred cleaning procedure.  If left up to me, I'd probably swish it around in a small container of gasoline and dry thoroughly with compressed air before reinstalling.
Is there a better method?
1972 Honda CB350 twin - sold
1976 Honda GL1000 Goldwing - sold
1996 BMW R1100RT - sold
2005 BMW R1200RT - sold
2011 Vespa GTS 300
2013 Royal Enfield C5 Military
2014 Honda CTX700N DCT
2014 Honda CB1100
mrunderhill1975a
Re: Dirty Oil Screen?
« Reply #1 on: July 28, 2013, 06:29:54 pm »
Do you have a UCE engine or an Iron Barrel?
« Reply #2 on: July 28, 2013, 06:37:30 pm »
It sounds like a UCE.
If it is, cleaning the oil screen that covers the mouth of the pump inlet by swishing it around in a solvent and blowing it dry is fine.
Just make sure the metal fragments and chips that are clinging to it are all removed. :)
While I'm writing, the face seal O-ring on the screen retainer will last for years and will always seal if it is just left in place and the metal surfaces are thoroughly cleaned.
Catbird
« Reply #3 on: July 28, 2013, 06:53:04 pm »
It's a 2013 with a UCE engine.
2011 Vespa GTS 300
2014 Honda CB1100
