Let me tell you, since I decided to replace my kick start pawl I have learned quite a bit.
To whit:
1. The kick start pawl wasn't slipping, it was the clutch. A simple turn of the adjusting screw would have allowed the clutch to fully engage and the kick starter work just fine.
2. When you reassemble the inner transmission cover, the washer the goes over the main shaft bearing goes flat side against the bearing. The washer has a lip on one side. Install it wrong and you wear a flat spot on the bearing (just discovered that today).
3. Snidal is wrong, the correct sealed bearing to allow use of standard weight gear oil is 6303 NOT 6305. Per Freemont Industrial, the 05 bearing is 8 mm larger than the 03 (the number on the OEM bearing is 6303). This makes sense since when I did a quick test fit, the 6305 bearing I ordered was way too big.
4. The lock nut for the detente plunger goes OUTSIDE the inner transmission cover. This might seem obvious (and of course it is), but I did it wrong anyway and there is enough room on the inside of the cover to allow the nut to be on the inside.
