G5 Classic
17 Guests, 2 Users
chuychacon, kodai
May 24, 2016, 08:55:23 am
Author Topic: Installing battery  (Read 1700 times)
squire
Installing battery
« on: July 26, 2013, 08:03:06 pm »
How do some of you get a replacement battery installed? I spent four hours today trying to install my new Motorbat battery without success. I tried every configuration of terminal ( the battery has adjustable terminals) and cable routing. I'm ready to reinstall the old battery or go pickup one of the new miniature batteries. I'm not a mechanic ( but a mechanical engineer) but without putting new fittings on the cables I'm at a loss. I even put a nice weld bead on my chrome fuel tank when I touched it with a wrench and ZAP.
GSS
Re: Installing battery
« Reply #1 on: July 26, 2013, 08:38:00 pm »
The original connectors are pretty flimsy and the configuration doesn't work for most non-OEM batteries. Most folks here have replaced those with heavy duty connectors from autoparts or hardware stores. It will also make it easy to connect your new battery.
GSS
« Last Edit: July 26, 2013, 08:42:52 pm by GSS »
2014 GT - Red
2010 C5 - Teal
It's a Jeep thing......
squire
« Reply #2 on: July 26, 2013, 09:09:23 pm »
Thanks. That's what I found odd, knowing the fittings are flimsy I tried everything to pull or twist them till they came off but no luck, they are there to stay. Guess I'll cut them off and pick up something different. My negative lead is none too long that's why I was hesitant to cut the cable if it wasn't necessary. My original battery is still usable but I was being proactive by replacing it. I have a new chain I'll be putting on to replace the original after reading some of the chain and sprocket horror stories on here. Thanks again.
wildbill
« Reply #3 on: July 27, 2013, 02:19:29 am »
mine went on my c5-what have you got
2011 C5 black/chrome
2012 C5 maroon/chrome
2013 B5 black
2014 Continental gt
2014 C5 tan
2015 black/chrome
2015 limited edition dispatch
2016 lagoon blue
2004 mazda-speed miata
2001 bmw z3
squire
« Reply #4 on: July 27, 2013, 09:53:17 am »
I have a C5 as well.
ROVERMAN
« Reply #5 on: July 27, 2013, 01:41:17 pm »
Do not wish to sound condescending but, i think you may want to leave this to a professional. Melting wrenches on batteries is scary and dangerous.
Please don't take offense, Robert & REnfield.
« Reply #6 on: July 27, 2013, 01:55:42 pm »
I guess the new battery doesn't have terminals with more than one screw thread in them?
The new battery I bought has two different threaded holes in each terminal along with some brass spacers.  That allows a number of combinations of attaching the wires.
The only place I could have gotten into trouble is they sell two different batteries in the size I needed.  The difference is the + and - terminals are reversed.
Had I bought the wrong battery there is no way my power and ground leads would have been long enough to attach without splicing in some extra wire.
squire
« Reply #7 on: July 27, 2013, 03:00:11 pm »
In 60 or so years of working on my bikes and cars I've had far more damage done to my vehicles by dealers than by my toying with them. The last time I took a bike to a dealer the tires were installed backward and the alloy rims damaged.....no thanks.
ROVERMAN
« Reply #8 on: July 27, 2013, 03:06:55 pm »
No problem man, just had to mention it.
squire
« Reply #9 on: July 27, 2013, 03:11:28 pm »
I'm not against dealers, when I retired from my real job I worked at dealers for a few years but not as a mechanic. If I had an RE dealer I could trust I would take it to him but unfortunately I don't. I'll figure the battery out. Thanks for your suggestion though.
TWinOKC
« Reply #10 on: July 27, 2013, 05:40:50 pm »
The most important thing is to get a replacement that is the correct size and the terminals are on the correct side.  This is one I had good luck with.
http://www.batterystuff.com/powersports-batteries/sYTX14AHL-BS.html
The price was right and delivery was quick.
I am sure there are others out there that will work just fine.
On mine, the battery terminals went toward the inside.
« Last Edit: July 27, 2013, 05:43:03 pm by TWinOKC »
2010  C5  Teal
2011 Triumph Bonneville T100
2015 Scrambler Ducati
Bulletman
  • 2011 - C5 Classic Black
« Reply #11 on: July 27, 2013, 07:45:09 pm »
« Last Edit: July 27, 2013, 07:59:37 pm by Bulletman »
"A Blast from my Past"
Mark F   (Northern, CA)
Black C5 2011
wildbill
« Reply #12 on: July 27, 2013, 07:59:09 pm »
2013 B5 black
2014 Continental gt
2014 C5 tan
2015 black/chrome
2016 lagoon blue
2001 bmw z3
« Reply #13 on: July 27, 2013, 08:43:06 pm »
The batteries shown in the link and the photo show what I was talking about.
The battery TWinOKC posted the link too has the negative terminal on the left side which seems to be the way the C5 is set up for.
The battery in the photos wildbill shows has the positive terminal on the left side like the one I bought.  It works well in the G5.
I don't know which battery the B5 uses but if you own one be sure to buy the battery with the same + and - terminal locations as the one that's installed on your bike.
TWinOKC
« Reply #14 on: July 27, 2013, 09:12:38 pm »
The + (on mine) is on the inside, toward the front of the bike.
Another way you could say it is + is on the left side of the battery when installed.
« Last Edit: July 27, 2013, 09:19:15 pm by TWinOKC »
2010  C5  Teal
