Royal Enfileld AVL
February 08, 2016, 07:56:32 pm
Author Topic: Installing Silencer To header pipe.  (Read 4698 times)
Re: Installing Silencer To header pipe.
« Reply #15 on: July 24, 2013, 07:08:17 pm »
Looks nice!  Did you do it at home or send it out to a company?
Ayers Garage
« Reply #16 on: July 24, 2013, 09:26:34 pm »
Thank you.  I run a powdercoating shop and do ceramic coating too. It's Cerakote from NIC industries. Your local coater likely uses NIC products if you ask him to do yours.
Royal Enfield. Speed limits aren't a restriction to me, they're a goal !
« Reply #17 on: July 24, 2013, 09:49:00 pm »
Thanks!  How much did it take?  At $70 a pint I think I will hold off until my chrome flakes off.
Sectorsteve
« Reply #18 on: July 25, 2013, 12:09:00 am »
a pikey set up atm but its working and there appears to be no leaks. the 2 pipes are exact same diameter which caused a little bit of a problem connecting them together. I just wanted to get it in place to try it out. rode about 100 miles today. I love this exhaust! Not really increasing punchiness but nice sound, can be quiet , can be loud, but really good on the freeway. i got up to record speed today - no shakes, no vibrations. brilliant. Got a really nice thump too. Think im just gonna weld the 2 pipes together at the join then heat wrap over the mess.
« Reply #19 on: July 25, 2013, 12:19:10 am »
Dr. Pepper is always good!
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
« Reply #20 on: July 25, 2013, 04:17:33 pm »
Look around on line, somebody makes a chrome step down, that will go over your header pipe, & into your muffler. Possibly even slightly upswept so you can't possibly drag.
Best Wishes, Craig McClure
Sectorsteve
« Reply #21 on: July 27, 2013, 09:30:00 pm »
You're right Craig. I need the angle extension. Right hand corners....
Bulletman
  • 2011 - C5 Classic Black
« Reply #22 on: July 28, 2013, 01:45:32 am »
   There is available a "step down pipe stub" to overcome 2 identical diameter pipes not joining.
Craig,
Where do you get the "step down pipe stub"....
Cheers.
"A Blast from my Past"
Mark F   (Northern, CA)
Black C5 2011
Sectorsteve
« Reply #23 on: July 28, 2013, 01:54:06 am »
Hey bullet man. What I did was found a peace of pipe that fit snug into my muffler, but welded the pipe onto the header and clamped the muffler /adapter. Worked a treat and meant only 1 clamp. There is an exposed weld, but I'm going to heat wrap the header and cover that.
Craig McClure
« Reply #24 on: July 28, 2013, 12:30:38 pm »
Goggle it, & search on Ebay. Also try the big M.C. parts houses "Bike Bandit, Bruce whatshisname". You Will find one if you look hard enough.
Bulletman
« Reply #25 on: July 29, 2013, 01:16:18 am »
Ah! Got it Sectorsteve...glad you got your muffler issue resolved as well..thanks for the info..
Cheers
Black C5 2011
Bulletman
« Reply #26 on: July 29, 2013, 01:18:03 am »
Will do...thanks Craig
Black C5 2011
wildbill
« Reply #27 on: July 29, 2013, 03:33:43 am »
Sectorsteve
pretty neat job-well done
2011 C5 black/chrome
2012 C5 maroon/chrome
2013 B5 black
2014 Continental gt
2014 C5 tan
2015 black/chrome
2015 limited edition dispatch
2016 lagoon blue
2004 mazda-speed miata
2001 bmw z3
« Reply #28 on: July 29, 2013, 04:15:26 pm »
For a lot of exhaust options Hardly parts outlets certainly carry a lot of stuff.
Sectorsteve
« Reply #29 on: July 30, 2013, 03:10:34 am »
thanks graham its working a treat. a little low and i thought id get an angle piece but ive adapted to that lowness, similar to the brake pedal and the center stand...
exhaust is rocking!
