Evening Ride
May 04, 2016, 04:47:32 am
Author Topic: Decarbonization, piston upgrade, drill case for old style breather  (Read 4119 times)
mattjohnson207
Re: Decarbonization, piston upgrade, drill case for old style breather
« Reply #15 on: July 27, 2013, 01:32:50 pm »
The good news is I haven't broken a fin. One case stud is hidden by starter, got the nut off...might still be exerting clamping forces.   Tried a brass drift, chisel, screwdriver ,  no movement.
    In another forum two contributors questioned the wisdom of opening the cases of a perfectly good motorcycle.  The breather mod will have to wait, but the iron barrel decomp valve is definitely going in!
     2009 AVL , 8,175 miles.  98%. Short  8 mile trips in Phoenix , Az , winter and summer .
       Was experiencing  intermittant metallic sound fom the head, marbles Now suspect i should have used  better gas mid grade or premium ,Regular kickbacks,   with an occasional clang.  won't restart when hot. Very hard starting
         Want to inspect rings and do decarbonization .
           ...Matt in Glendale
« Reply #16 on: July 27, 2013, 02:32:58 pm »
Are you sure you've taken the nut off at the bottom of cylinder on right side. If that's off the cylinder should come off.   ERC
mattjohnson207
« Reply #17 on: July 27, 2013, 09:47:30 pm »
I loosened  three nuts just below the cylinder. The starter ,or front side has only one nut accessible , other side is blind.  The rear, both nuts are loose
« Reply #18 on: July 28, 2013, 07:11:35 am »
Try taking the studs out then you may be able to swivel the cylinder.  ERC
« Reply #19 on: July 28, 2013, 08:00:28 am »
I would suspect that it is the gasket that is holding it down, by way of some gasket compound that they used, or just the gasket itself getting bonded to the castings from heat and time. I see this on the Iron Barrels too.
If you can't get it off using any other method, you can use a thin paint scraper and a mallet to drive the thin blade of the paint scraper into the gasket gap, thereby destroying the base gasket. Work it all the way around from all sides, and this loosens the grip of the gasket on the castings.
If it still won't let go, you can then use a thicker wedge in the gasket gap to wedge the cylinder up, by using a mallet to drive the wedge into the gap, at various places around the base, to move it up evenly. At some point, it gives up and you can get it off.
Just be sure that there are no bolts or studs remaining un-done, and it will come up with methods like this.
« Reply #20 on: July 28, 2013, 11:13:08 am »
Ace is correct on the putty knife use, but the best one I found is the Snap On chisel edge heavy duty gasket scraper. You can really whack it with a hammer and it won't bend and if carefully placed on the gasket edge will cut into the gasket not harming the surfaces.  ERC
« Reply #21 on: July 28, 2013, 11:48:44 am »
Can't improve on those recommendations 'cause they're what I've done on various parts and bikes.  I usually use a stainless putty knife with a beveled edge.  If the cooked on gasket still won't break loose, try soaking overnight with a real penetrating oil like Kroil or Liquid Wrench.  PB Blaster if it's what you have.  That will usually soften the paper gasket and dissolve some of the hardened adhesive.
« Reply #22 on: July 28, 2013, 11:54:15 am »
A good quality putty knife and hammer/dead blow will usually do the trick.  If it doesn't, resort to obscene profanity and beer and try again.  THAT will usually do the trick.    :D
« Reply #23 on: July 28, 2013, 12:10:29 pm »
If you can't take it off without undo force, call Scottie and his drunken cussing should scare it loose!  ;D
Hey, I've been guilty of resorting to that myself.  Beer and cussing, not calling Scottie.
mattjohnson207
« Reply #24 on: July 28, 2013, 02:31:19 pm »
Paint scraper did the trick.  Crescent is about 1/16" deep. If that's not enough, is it a big deal to remove the piston?  Then I'll get out the grinder, make it a little deeper , if necessary?( sealing off the bottom end with some kind of silicone and whatever) and drill for the  brass breather elbow
        We'll worry about getting the correct amount of vacume  later. How hard can it be...
         However, this is my first rodeo, took an engine building class at the community
 College ten years ago;  any advice I can get I will be happy to get.....Matt
mattjohnson207
« Reply #25 on: July 28, 2013, 02:46:54 pm »
The lines in the barrel are of course the front of the bike, only one line is visable to the naked eye, thought it was a scratch from pulling out the barrel, can't feel any roughness.
       The piston rocks from side to side about an eighth inch.       Matt
« Reply #26 on: July 28, 2013, 03:04:56 pm »
An 1/8" of play on the wrist pin seems a bit excessive and worn IMO.  Maybe pull the clip and wirst pin and inspect for excessive wear on the pin itself and on the piston.  Look to see if there are any areas where metal has been worn off.  If there is you need to replace the piston, rings and wrist pin.  Also make sure you inspect the cylinders walls very well, and take a peak at the top of the piston rod while you're at it.
You already have it this far, make sure you give everything a very thorough inspection.  How many miles BTW?
mattjohnson207
« Reply #27 on: July 28, 2013, 03:30:43 pm »
Got as a leftover, mostly 8 mile trips to work in Phoenix. At 45 mph; summer is hot, winter probably doesn't warm up. 8,175 miles.
       You're. Right...got it this far, might as well do it right
mattjohnson207
« Reply #28 on: July 28, 2013, 03:35:43 pm »
And there was that intermittent sound of marbles, hard starting, clanging kickbacks, which is why I'm here...
« Reply #29 on: July 28, 2013, 04:22:46 pm »
That marbles sound could very well have been that loose wrist pin.  It shouldn't have any play at all.
