24 Guests, 2 Users
kodai, JohnDL
May 24, 2016, 08:48:14 am
Author Topic: 2008 Bullet Electra Classic 500  (Read 1022 times)
Buckeroo
« on: July 18, 2013, 12:44:23 pm »
I have recently learned that I have an odd mix of classic frame with an AVL motor.  The exhaust pipe passes right in front of the oil filter.  There is no warming the bike up and removing the cap as I can see it.  The previous owner never rode the bike more than 25 miles and then it sat in storage for 3 years.  I took charge of it and have had to remove the pipe each time to change the oil filter.  Is there another pipe that can be had to clear the filter better that will fit this application?  Thanks for any help.
Classic Frame and AVL motor
Electric Start
Electronic Ignition
5 speed
CV Carb
Re: 2008 Bullet Electra Classic 500
« Reply #1 on: July 18, 2013, 01:40:20 pm »
 The factory original pipe for your model was a bit straighter and had tighter radius bends unlike the lovely sweeping pipe in its place now.
New or used factory pipes are certainly gettable.
Have you called CMW ?
« Reply #2 on: July 18, 2013, 05:18:19 pm »
You might be able to twist the pipe coming out of the head just by loosening all the bolts and clamps. There should be some play in there. I moved mine in a couple of inches when I got the stock footpegs and rear brake pedal out of the way with rear sets. Should be possible to go the other way.
bare
« Reply #3 on: July 18, 2013, 06:47:54 pm »
       Hey Buckeroo,
              You don't have "an odd mix" of frame & engine. What you have is the same bike I have: a 2008 AVL Classic. The Electra & the Classic are two separate models.
               The first time I changed my oil, I had the same fiddley time as you, but I'm used to fiddling. I didn't have to remove the pipe.
              Later I learned I could gain some tiny bit by loosening the header pipe & muffler nuts & cranking here & there then retightening the header pipe nuts.
              It's not nearly as bad as some things I've had to fiddle with.
2008 ACE Head AVL Classic
« Reply #4 on: July 18, 2013, 08:59:50 pm »
I think the silencers position has a lot to do with how far in or out the exhaust header is positioned.
If the exhaust was loosened at the cylinder head and the silencer was moved outward a bit with a few "fender washers" to move its clamps away from the frame support it might give the extra room needed to get the oil filter in and out?
Buckeroo
« Reply #5 on: July 18, 2013, 09:19:19 pm »
Who is CMW?
Electric Start
Electronic Ignition
5 speed
CV Carb
Buckeroo
« Reply #6 on: July 18, 2013, 09:41:48 pm »
I think it's odd because it took me awhile to figure out it wasn't either a Classic or an AVL, but a mixture of the two that was made for one year, perhaps two.  The discussion groups here don't cover this in between model.  So it's frame question over there, engine question over here.  And who knows where for parts that connect, like the exhaust pipe.  I like the quiet sound and I like the curved pipe, but I don't like how it seems that there is not much play to get it away from the filter.
       Hey Buckeroo,
Electric Start
Electronic Ignition
5 speed
CV Carb
« Reply #7 on: July 18, 2013, 11:23:59 pm »
There are basically three different frames and the differences are fairly minor until you want to add an aftermarket item.
The three engines: the old iron barrel, the AVL and the new UCE have been mounted in all of these frames at one time or another so feel free to ask any frame question about your AVL Classic right here in the AVL forum. :)
« Reply #8 on: July 19, 2013, 12:57:48 am »
Who is CMW?
Sorry bout that.
 CMW a.k.a. Classic Motor Works is the US R.E. importer.
The parts and accessories departments were spun off into their own subsidiary awhile ago that is now know as NField Gear or NFG though many of us still (incorrectly) refer to them as CMW out of habit.
 Calling on the phone is preferable to emails.
« Last Edit: July 19, 2013, 01:06:38 am by Ice »
« Reply #9 on: July 19, 2013, 07:32:07 am »
           This IS the correct forum for your bike. The "Classic" forum deals more with the Iron Barrels, NOT with the AVL Classic Model which is what your bike is. The "Classic" in the Classic Forum forum does not refer to the Model Classic which is an AVL.
            If you're going to deal with NField Gear for parts you have to refer to your bike as what it is: A 2008 AVL Classic. It's not an "odd" model or an orphan. It's exactly the bike (an AVL Classic) that I
& hundreds of others have so welcome to the AVL Forum & I'm just trying to help you refine your definitions here.
« Reply #10 on: July 19, 2013, 07:52:10 pm »
Just do what Arizoni says to fix your filter problem.  ERC
Buckeroo
« Reply #11 on: July 20, 2013, 01:11:31 pm »
Okay, thanks.  Talking on the phone appears to be the only way to find a solution.  Thanks for the explanation of CMW which I see commented about many places here on the forum.
Sorry bout that.
Electric Start
Electronic Ignition
5 speed
CV Carb
