Good.
A leak into the plastic plenum would be bad because the engine breaths it's air from the outside surface of the air filter. A leak on its lid would let in a lot of dirt directly into the engines intake.
The metal outer cover can be a real annoyance and more than one of them has totally lost its lock. A gap between the lid won't actually cause any harm to the engine though.
Good luck with your K&E filter. On my G5 I lost some preformance and my fuel mileage dropped about 10 miles/gallon.
That's why I went back to the OEM paper filter and sit the K&E on my shelf to remind me that sometimes expensive things don't improve things.
Speaking of the metal cover, on my G5 it's a real PITA to open.
I found that in order to just turn the key I have to press the cover in at the bottom with a LOT of force. There's a hard rubber block behind it that pushes the lower area out so hard that if I don't push it in, the key refuses to turn.
