Solo 2
15 Guests, 0 Users
February 13, 2016, 04:50:41 am
Author Topic: Solved: Battery Exploded  (Read 738 times)
edthetermite
  • The Emperor has no skin.
« on: July 17, 2013, 02:49:14 pm »
Something went askew with my charging system as my Yuasa dry cell battery exploded today. See pic.
Haven't checked things out yet but beside the voltage regulator going wacky what else would cause the battery to split the case?
The last few times I rode the Bullet I noticed the ammeter needle staying to the right all the time and about midscale on the + side of the gauge.
This was an identical battery to the one that came on the bike new and the first one lasted 5 years nearly.
Update: received new battery and troubleshot problem. Revving engine produced over 17 volts at battery. Swopped out alternator module and things dropped back to the 14's.
If your ammeter needle stays well into the positive area for extended periods of time you might want to doublecheck things.
« Last Edit: July 20, 2013, 06:09:46 pm by edthetermite »
Ed   - Long Live the Iron Barrel !!!!
2008 Military RE "535"    2006 Ural Gear Up
Re: Battery Exploded
« Reply #1 on: July 17, 2013, 02:58:51 pm »
A severe overcharge on a hot day could do it.
edthetermite
« Reply #2 on: July 17, 2013, 03:07:14 pm »
Would a 'severe overcharge' only occur if the regulator is tits up? It was about 92 outside when the failure occurred.
« Reply #3 on: July 17, 2013, 03:16:25 pm »
That would be a good likelihood.
A short circuit inside the battery could also do it.
« Reply #4 on: July 17, 2013, 05:00:18 pm »
I've seen them crap out from vibration.   ERC
edthetermite
« Reply #5 on: July 19, 2013, 10:38:11 pm »
I pled my case with the folks at BatteryStuff.com and they took the position that only something external to the failed battery could of caused it to become overcharged to the point of rupturing the case. They did give a healthy credit toward getting another battery, which was appreciated.
Proving unconvincingly that the battery failed on it own would be difficult I'm thinking.
edthetermite
Re: Solved: Battery Exploded
« Reply #6 on: August 10, 2013, 08:18:13 am »
Replacement battery (Scorpion) lasted a few weeks before developing an internal plate short after warming up. Left me on the side of the road again. My wife is getting very annoyed with picking me up.  :'(
Maybe I need to go back to a Yuasa?
