Author Topic: led mystery  (Read 3311 times)
sethne
on: July 16, 2013, 04:47:22 pm
hey guys
got a mystery here.  last night i replaced my high beam indicator, speedometer, neutral and turn signal indicator lights to leds.  i believe i have everything wired correctly... "believe..."  now unless my mind is playing tricks on me, the headlight is dimmer than it used to be and the high beam indicator led has a faint glow to it.  This glow gets brighter the faster i ride and goes back to a faint glow when stopped.  Any ideas?
Reply #1 on: July 16, 2013, 05:22:55 pm
Sounds like you may have wired something wrong.  Sounds like a crossed wire to me.  I'd open it back up and take a double look.  Probably something silly.
D the D
Reply #2 on: July 16, 2013, 06:11:53 pm
There's nothing to rewire, just pop the old bulb out and pop the new one in.  So I don't see how you could wire it wrong.  Worst case would be to put the bulb w/connector back in the wrong hole, i.e. put the high beam indicator socket in the neutral indicator hole.
1975 XLCH
gashousegorilla
Reply #3 on: July 16, 2013, 07:09:38 pm
  These LED's.... are they polarity sensitive ?... You might just have to turn the bulbs around in their sockets .... The case on the socket is ground - and the center inside is hot +
  Also, i'd leave that indicator light an Incandescent....
« Last Edit: July 16, 2013, 07:32:00 pm by gashousegorilla »
gremlin
Reply #4 on: July 16, 2013, 08:11:29 pm
hey guys
sounds like a disconnected ground wire.
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
gashousegorilla
Reply #5 on: July 16, 2013, 08:23:14 pm
gremlin
Reply #6 on: July 16, 2013, 08:25:11 pm
  Also check this...............
http://www.expeditionlandrover.info/LR.images/HeadlampSocket.jpg
+1  I don't know if the colors in that diagram are correct, but, if the lamp wiring got scrambled, he might be trying to illuminate both elements in series.
« Last Edit: July 16, 2013, 08:31:44 pm by gremlin »
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
gashousegorilla
Reply #7 on: July 16, 2013, 08:42:36 pm
  YUP!!  And No, I'm sure they're not color coded the same Gremlin.  But with a test light he should be able to operate the switch and see what's .....What.   Then splice in a socket..... so it don't happen again  !   Ask me how i know this........ ::)
gashousegorilla
Reply #8 on: July 16, 2013, 10:31:11 pm
  Unfortunately sethne,  the color codes don't always match between whats on the bike.... and whats on the wiring diagram.  But I'll give it a go for you , if you want to check that headlight hook up.... and I'd confirm this with a test light or a multi meter by operating the high and low beam switches......
  Blue wire at the headlight - High beam
  Amber or orange wire at headlight-  headlight ground
  Black wire at headlight-  Low beam
 And I know, black is usually ground. But not in this case. At Least not according to the diagram. Which could have led to your confusion..... as well as mine.
  Here is a better example.  Disregard these color codes...... but the terminal positions on the plug and headlight are correct .
http://www.nls.net/mp/volks/schem/headlite.gif
« Last Edit: July 16, 2013, 10:48:55 pm by gashousegorilla »
sethne
Reply #9 on: July 16, 2013, 11:33:54 pm
yep, oddly enough that wiring matches up with mine.
Bulletman
  • 2011 - C5 Classic Black
Reply #10 on: July 16, 2013, 11:39:49 pm
+1
The LEDs are polarity sensitive, I've been through that process, so it's good to change polarity...may not be able to turn the bulb around..in my case I have to switch the wires.
"A Blast from my Past"
Black C5 2011
Reply #11 on: July 17, 2013, 12:47:05 am
Make sure the headlight is wired correctly. It's easy to get a power wire hooked up to the ground connections. Check these connections carefully. I know I went through the same thing! Those headlights are not all the same.
sethne
Reply #12 on: July 17, 2013, 03:41:52 am
Problem goes away when I go back to the incandescent indicator bulb. Also happens no matter which polarity I put the led in. I decided to leave the incandescent in, no need for a laser beam bright indicator for the high beam.
D the D
Reply #13 on: July 17, 2013, 03:57:15 am
These things get odder and odder.  No two react to the same changes the same way, exhibit the same symptons, have the wiring the same, or anything else.
1975 XLCH
Catbird
Reply #14 on: July 23, 2013, 10:42:18 pm
  ...  Also, i'd leave that indicator light an Incandescent....
Why?
I have a new 2013 Military and I have some difficulty in seeing the green "neutral" and green "turn signal" indicator lights when the sun is overhead and bright.  As a remedy, I ordered 4-LED replacements (2 green, 1 blue and 2 white for the pilot lights) today.  Viewing the results on youtube, the LEDs appear MUCH brighter... am I wrong?
1972 Honda CB350 twin - sold
1976 Honda GL1000 Goldwing - sold
1996 BMW R1100RT - sold
2005 BMW R1200RT - sold
2011 Vespa GTS 300
2013 Royal Enfield C5 Military
2014 Honda CTX700N DCT
2014 Honda CB1100
