Use JB Stick!
I have used that stuff on header pipes and engine blocks. SUPER super durable and is not really affected by heat. I had a hole in my dirt bike exhaust where the bike went down and a rock smashed a hole in the head pipe. A little 80 grit sand paper, clean it off with some brake cleaner, get the putty ready, apply and you're good to go.
A little secret for you guys: When working with welding putties like JB Stick, wear latex gloves and dip the fingers in acetone or brake cleaner to smooth out the finished surface before it hardens.
