This is just a thought. n I have not tried it yet, but I might if I can figure it out in a way that looks like it belongs on the bike. I have not removed the jumper as Georgia law required the lights to be on at all times. A weak battery would make it a problem to start with the headlights on, but removing the jumper could result in a ticket if you forget to turn lights on. Suggestion: Remove the jumper and put a bright LED across the switch. With the switch off, the LED is on when the ignition is on. With the light switch on, the LED is shorted and goes off. When the switch is off, current flows through the LED and the lights, but the current draw of the LED is not enough to light the headlamp and would not be a noticeable load even on a weak battery trying to turn the starter. But where to mount the LED so it looks right? GA-DK
