Author Topic: tachometor  (Read 3220 times)
victorygreg
on: July 13, 2013, 10:35:51 am
has any one found a tachometer small in size and a reasonable price?  Thanks, Greg
Royal Enfield  Can-Am Spyder  Ural  Victory Classic
wildbill
Reply #1 on: July 13, 2013, 11:45:58 am
how about the small digital tachs on ebay for 20 bucks
Ekatus Atimoss
Reply #2 on: July 13, 2013, 02:47:05 pm
48mm diameter small enough?
dopo notte, atra e funesta, splende in ciel più vago il sole e di gioia empie la terra
2012 C5 built for comfort, not for speed (click for pictures)
Joel-in-dallas
Reply #3 on: July 13, 2013, 04:28:26 pm
I would love to have a small tach!
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
Reply #4 on: July 13, 2013, 05:35:06 pm
Tachometer is just an unnecessary bother unless your deaf.
Best Wishes, Craig McClure
Gypsyjon
2bikebill
  • ~ it's about the ride ~
Reply #6 on: July 13, 2013, 09:33:54 pm
Blairio
Reply #7 on: July 14, 2013, 07:01:16 am
The TTO Tachometer displays rpm when the engine is running, and when you stop the engine it displays the max rpm reached and total run time in hours. You don't need to interfere with any of your bike's wiring, as its only input is from a wire coiled round the engine's HT lead.
And if you get bored with it on your bike, you can always stick it on your lawnmower...
singhg5
Reply #8 on: July 16, 2013, 12:57:35 am
This is a cute little easy DIY TTO tach-hour sold by Trailtech.
http://www.trailtech.net/tto_tach-hour.html
To my knowledge it has an internal battery that is good for 5 years and the battery is non-replaceable. Will need to buy new tach every five years - not so bad for the price and convenience.
« Last Edit: July 16, 2013, 01:37:52 am by singhg5 »
1970's Jawa /  Yezdi
2006 Honda Nighthawk
2009 Royal Enfield Black G5
D the D
Reply #9 on: July 16, 2013, 03:07:07 am
I put one of those on my riding mower.  Still working after 7 years.  The only hookup is to wrap the inductive lead around the spark plug wire and secure it with a tie-wrap or tape.
1975 XLCH
Reply #10 on: July 16, 2013, 04:35:29 am
I kind of like that little guy.  I like the simple installation and the fact that it records max RPMs and hours.  Not bad for $38.  The only problem I see is no back lighting, but that's not a biggie.
Portland Bullet
  • 2011 B5
Reply #11 on: July 16, 2013, 03:19:18 pm
+1
The Portland Bullet
To Dream, to Live, to Ride
2011 B5 Bullet 500cc
Reply #12 on: July 16, 2013, 03:33:25 pm
I disagree.  While I NEVER use the tach as a shift point guide when I'm getting on it, it IS nice to know where your motor is spinning.  Especially at highway speeds on these bikes.  When cruising down the interstate, it would be really nice to know just where the motor is at speed wise so you can reassure yourself you don't overheat and lockup the motor.  For me, it would be nice to have the Max RPM read back after taking a pass down the 1/4 mile or a run around the dirt track.  You can even use a tach to help calculate gear ratios for the crank shaft and counter shaft gear sprockets to obtain your most efficient set up for your needs, whether for torque or speed.
So, no, tachs are not "unnecessary".  While not for everybody (and everybody has their own opinion) I have to say that they do have their place.
gashousegorilla
Reply #13 on: July 16, 2013, 03:54:00 pm
  What he said...... ^^^
2bikebill
Reply #14 on: July 16, 2013, 07:33:14 pm
+ 1
no one said it was a necessity, just nice to have...
like a motorbike, or two, or more... ;)
« Last Edit: July 16, 2013, 07:35:30 pm by WillW »
