The Fonz?
August 04, 2015, 06:45:47 am
Author Topic: HELP please! magneto identification  (Read 922 times)
tim15328
« on: July 09, 2013, 10:23:26 pm »
These are a couple of pictures from magneto from a 1958 royal enfield trailblazer. Im pretty sure it is an sr2... obviously lucas. The reason im worried is im looking to get a electronic ignition (recomendations wold be great).  Ive also been told by a mechanic that the cap has a extremely small crack (I cant find it), will this effect the capabilities of the bike?
Thanks tim
D the D
Re: HELP please! magneto identification
« Reply #1 on: July 09, 2013, 10:28:19 pm »
Tim, no pics!
1975 XLCH
tim15328
« Reply #2 on: July 09, 2013, 10:28:45 pm »
Heres the pics
« Reply #3 on: July 09, 2013, 10:37:17 pm »
That is definitely a SR2.  Weird, my Trailblazer has a K2F mag.  Then again, it also has a bunch of other different stuff apparently.  I went with the Thorspark ignition of off Ebay, they have a set up listed for the SR1, send them a message and see if they have one for your SR2.
http://www.ebay.com/itm/Lucas-Magneto-Electronic-Ignition-rewind-recondition-K2F-Mo1L-N1-K1F-magdyno-SR1-/151024720905?pt=Motorcycles_Parts_Accessories&hash=item2329c65c09&vxp=mtr
Can you please post a pic of your casquette/instrument cluster?  I was told mine is set up differently than most and would like to see what yours looks like.  Thanks!
SRL790
  • 1954 350
« Reply #4 on: July 11, 2013, 03:50:38 pm »
Tim,
You might want to check out these guys too.
http://www.srmclassicbikes.com/
Andy
Andy Wiltshire
ERC
« Reply #5 on: July 11, 2013, 05:44:06 pm »
I think most of the Electronic Ignitions require 12 volts from a battery to work. All the parts to repair your SR2 are still available. You may be better off repairing what you have. It's one of the simplest mags made.   ERC
« Reply #6 on: July 12, 2013, 08:02:45 am »
The Thorspark you can order in 6V or 12V and positive or negative ground/earth.  But, yes, you will need at lest a small battery.
