Author Topic: 05 bullet 500 Motor rapping  (Read 3325 times)
byker1
on: June 11, 2008, 11:19:11 pm
2005 Bullet 500 with about 1000 miles on it.  Oil was changed at 800 miles and looks full and clean.  Engine made some scraping noise occasionally or maybe was pinging could not identify where noise was coming from.  The bike stalled and now the motor is rapping.  Any suggestions on what to look for?
Thanks
deejay
Reply #1 on: June 12, 2008, 02:37:41 am
I'd try to retard the timing 1st
Leonard
  • I loved this bike!!
Reply #2 on: June 12, 2008, 02:58:15 am
Don't quite understand what you mean by rapping.  The bike stalled, I assume you were able to get it restarted.  Try to explain the scraping noise, what was going on when you heard that.  Did you do something to make it stop?
Thanks
2009 Triumph Bonneville T100
http://www.romeoriders.com
DireWolf
Reply #3 on: June 12, 2008, 02:02:05 pm
pinging, now rapping?
Is it the valves?  Maybe need tappet adjustment.....
Worth checking, anyway.  Easy to do.
Reply #4 on: June 12, 2008, 03:19:29 pm
Piston seizure, maybe? Hey, it isn't like it can't happen..
byker1
Reply #5 on: June 14, 2008, 01:19:42 pm
It's making a racket now.  I know noises are hard to explain.  We are going to look at it this afternoon and maybe I will have a better explanation.  I'm going to change the oil and filter.  Hand crank it and check the valves.
Here is an odd thing - the oil looks like the day we put it in.  bad oil pump?  blocked oil filter?
All thoughts are welcome.
the Sound is hard knocking noise.  When the bike stalled it was sitting at a traffic light.
it would not restart at the light but did after pushing it into a gas station and letting it sit for a few minutes.  We ran it for maybe 10 seconds then shut it down.  we haven't tried starting it again.
the scraping noise sounded like low octane ping when letting off the throttle after normal acceleration.
dogbone
Reply #6 on: June 14, 2008, 03:25:50 pm
It sounds like the dreaded piston seizure to me, I've burnt up 2 pistons !!!
the Quality of the oem piston is poor to shitty. At 1000 miles, let the dealer cover it
99 Enfield Bullet 535
Leonard
Reply #7 on: June 14, 2008, 05:14:43 pm
I agree with dogbone,  if it were me I'd get it to the dealer ASAP.  Sounding like a big end or piston failure.
byker1
Reply #8 on: June 14, 2008, 11:30:03 pm
Turns out the exhaust tappet retaining nut had backed off and there was about 1/2" of play in the pushrod.  What a sound!  I thought for sure we had burned the piston but came here for some suggestions.
Thanks everyone.
It seems to be running great now but still need to test ride it.
Byker1 & Lady Enfield
DireWolf
Reply #9 on: June 18, 2008, 09:21:45 pm
Thanks everyone.
Good deal.  That thing can sound like an AK-47 if it gets too loose........
Reply #10 on: June 18, 2008, 10:14:42 pm
I'm surprised that with 1/2 inch of slop it even ran at all. It should have quit running or at least let you know long before that.
Glad it worked out for ya.
1972 FLH "Sambo"
2023 Guzzi V7 Special "BOB"
