In the fields
27 Guests, 5 Users (1 Hidden)
Grant Borden, Under The Redwoods, ace.cafe, Hondo
May 04, 2016, 08:02:56 pm
Author Topic: Neutral Finder  (Read 464 times)
vonfilm
Neutral Finder
« on: July 08, 2013, 02:44:04 pm »
Can someone refer me to some clear instructions for adjusting the neutral finder on my 2002 Bullet 350ES ? I found the instructions in the Snidal manual to be a little confusing.
Catbird
Re: Neutral Finder
« Reply #1 on: July 08, 2013, 04:22:07 pm »
I have no idea, but you may find something useful here...
http://www.youtube.com/watch?v=9M8sbGg3aZQ
1972 Honda CB350 twin - sold
1996 BMW R1100RT - sold
2005 BMW R1200RT - sold
2011 Vespa GTS 300
2014 Honda CTX700N DCT
2014 Honda CB1100
Chasfield
Re: Neutral Finder
« Reply #2 on: July 09, 2013, 04:15:43 am »
I lost the adjustment of mine when I fitted the Hitchcock's outer gearbox cover stiffener kit (which does save a bit of lost clutch lift and sweeten up the gear change). The kit uses the mounting hole for the eccentrically drilled stop bushing that the neutral finder bears against. Of course, I should have marked the orientation of the eccentric bush when I dismantled the outer cover...
However, I reinstalled the bush to what looked about right but I didn't have enough bush wall under the neutral finder so it was pushing through all the way to first gear. Then, I rotated the bush so that it held  the neutral finder lever a bit higher. This time, the lever couldn't drop enough to let go of second gear. I then set it to somewhere in between and it now works properly.
The adjustment seems quite critical so I will mark the position of the bush - the extra cover stud of the stiffener kit means that the bush has to be disturbed every time the outer cover is removed.
Other posters could maybe advise if there any other adjustments to make under the outer cover.
« Last Edit: July 09, 2013, 11:01:29 am by Chasfield »
2001 500 Bullet Deluxe
mrunderhill1975a
Re: Neutral Finder
« Reply #3 on: July 09, 2013, 10:17:10 am »
You can find a complete description is at the following link:
http://www.cybersteering.com/cruise/feature/bullet/adj_neutralfinder.html
The last few lines are the most important.  That is: "Park the bike with some "packing" under the centre-stand, so that the rear-wheel is free to rotate. Loosen the bolt holding the eccentric, turn it so that the "big-side" is down. Now start the engine and engage second gear. Slowly pull the neutral-finder down till it slips out of gear. Turn the eccentric to stop the lever at that position. Tighten the bolt."
