fantush 2
May 30, 2016, 07:39:35 am
Author Topic: Cylinder head washers  (Read 817 times)
toyo
« on: July 07, 2013, 02:09:25 pm »
Purchased the hardened washers from Hitchcocks.
How do you remove the standard washers that got crushed in the holes? They made the head difficult to remove.
Re: Cylinder head washers
« Reply #1 on: July 07, 2013, 02:16:54 pm »
Try to get a small punch in from the bottom, you can sometimes just catch the edge of the washer and knock it out. If they're really jammed heat around the area then knock them out. Also a drill bit or bolt extractor will work. It's just be patient. You just don't want to ruin the aluminum.  ERC
« Reply #2 on: July 07, 2013, 02:28:18 pm »
I used a piece of drill rod that barely fit into the holes as a drift and tapped them through from the bottom up.  A regular drift will work too, just make sure the tip is ground flat and not rounded from previous use.
toyo
« Reply #3 on: July 07, 2013, 09:09:26 pm »
Wow! Thank you for your prompt resopnse like hand flag signals :)
toyo
« Reply #4 on: July 08, 2013, 07:18:33 pm »
In her case the only solution seems to drill thru, as the washers are really jammed. Is the drill size you used 11/32"? - my measurement of the hole size is about 8.7 mm. My closest drill bit is 8.5 mm that will not solve the problem ....
(We use metric, inch tools are not common at tool shops ...)
« Last Edit: July 08, 2013, 08:02:30 pm by toyo »
« Reply #5 on: July 08, 2013, 08:01:30 pm »
I didn't use a drill bit.  I just picked through some blank drill rods I had laying about and tried them in turn.  Not sure the size as it wasn't marked and I didn't measure.
« Reply #6 on: July 08, 2013, 08:15:33 pm »
Try heating the area. Then try tapping them out.  ERC
toyo
« Reply #7 on: July 09, 2013, 09:57:54 pm »
Thank you all,
the old crushed washers (that made very hard to remove the head) have been removed without mistakes and pitfalls - no damages to the head. Saved a lot of my beer money  ;D
The hardened washers have been in place, that should make a lot easier to remove the head next maintenance.
« Reply #8 on: July 09, 2013, 10:27:30 pm »
YAY!
