Took my 99 bullet 08 thruxton out of winter storage
36 Guests, 2 Users (1 Hidden)
February 07, 2016, 02:51:59 am
Author Topic: Greetings from the Commonwealth of Virginia  (Read 1694 times)
Catbird
Re: Greetings from the Commonwealth of Virginia
« Reply #15 on: July 07, 2013, 08:36:18 am »
...Welcome Catbird. An REM will handle anything you need to ride on. Maybe not at the speed you think you need.
Thank you.
Maybe it's my basic personality (or my advanced age of 65), but I'm not too much into super high speed riding.  I have always preferred to ride at reasonable speeds and enjoy the scenery and soaking in my surroundings.
1972 Honda CB350 twin - sold
1996 BMW R1100RT - sold
2005 BMW R1200RT - sold
2011 Vespa GTS 300
2014 Honda CTX700N DCT
2014 Honda CB1100
Guaire
« Reply #16 on: July 07, 2013, 08:56:25 pm »
I went through Luray back in May. DC MD VA Ride posted on May 28, 2013. Check out the photos in Paint Bank with the Triumph Thruxton. The rider was 70!
Hurricane
« Reply #17 on: July 22, 2013, 05:21:33 am »
Friday 7/19...In my daily truck, I followed a Military Bullet on US Rt.15 from Gainesvillle, Va until I broke off at Frederick, MD.  Tried to keep some of the typical aggressive northern VA drivers off your tail.
You had New York plates, panniers and solo seat...so are you local or travelling through ?
Hurricane
« Reply #18 on: July 22, 2013, 12:51:23 pm »
These 500s were basically designed in the late forties and were intended for the working man to commute on the road of the 40s and were not categorized at sport bikes. As we called them then, they were duffer bikes made to use the roads of the day and cruise 40-50 mph.
Royal Enfield, England, made some somewhat sportier versions in the late '50s and '60s, but these were not what the Indians were building. They had contracted to build the '55 version and made little attempt at upgrading them over the many years of production as they were originally meant for their police and army. Had Enfield remained in a good business stance in the60s they probably would have produced a unit construction 500 as they already had a 250 and 350 unitized. Basically the Indians have now done that with the UCEs. It's still basically the same old duffer engine unitized and thrown in some far better metallurgy, electronics and fuel injection. The engine has better performance because of the improved materials which allows for higher continuous RPM ranges.
Actually, the breakin is more akin to modern engines where you just ride it. Avoid high RPM and loads during the breakin time and ride it in the twisties if available so the gearbox gets a workout, too. It needs to be broken in also. I broke mine in most by figuring out where the half throttle spot was and not exceeding it for about 500 miles. That offers adequate acceleration in traffic and reasonable speeds through the gears, I ran mine generally up to about 55 in that period. After the 500 or so just start increasing the speed in steps for the next 500 and by 1000 miles it will be fairly well broken in. This procedure is pretty much what our sponsor, Kevin, recommends. The breakin procedure in the book was never changed from the iron barrel, 4 speed days and just isn't applicable to the new bikes. Basically, just ride it sanely and you will be fine.
Keep an eye on the chain. You will get tot the point that adjusting it every couple of hundred miles is required.  It's time for a new one. Get a quality chain from a reputable manufacturer. Get it before it eats your sprockets
« Last Edit: July 22, 2013, 12:55:41 pm by barenekd »
jkrobin
« Reply #19 on: August 01, 2013, 07:16:43 pm »
Just another hello from here in the Commonwealth. If any of you are down here in Charlottesville, I'm always up for a nice leisurely RE ride.
2012 C5 Chrome (Black)
Charlottesville, Virginia
