Do the UCE bikes with EFI get primed when kicked over with the key off?
I think, but oil - kicking through pumps some oil, perhaps...
When you crank the engine whether by foot or by electric motor you run everything mechanical. The alternator turns, the clutch turns, the lifters lift, the valves open, and the oil pump pumps oil. If that doesn't happen, it's major broke.
...and this is an answer to what?
"Do the UCE bikes with EFI get primed when kicked over with the key off?
