Author Topic: Newbie needs your help please  (Read 1055 times)
Samir72
on: June 30, 2013, 05:04:30 pm
Thanks Arizoni,
Well, I bought a 2009 Bullet Chrome with about 1500 miles on it about a year ago in Florida from a Dealer. The bike was immaculate, garaged and had a few modifications:
right-shift gear box
battery relocated
no turn signals
air filter is not stock, it' in a round chrome container that is partially open, maybe 4 inches in diameter, not sure of the exact name/type
So, I should tell you that this the first bike I ever owned/rode. I was in India for 2 months and want to go back to ride in the Himalayas, and since most the rentals there are right-shift Enfields I figured I'll just get on and learn here instead of India.
Soon after I rode it off the lot I started having problems. The bike would suffocate sort off. It would stall out at traffic lights etc. I went back and Chuck, the Dealer, said my exhaust/catalyc converter failed. He put another exhaust on and it seemed to ride well for a short while. The exhaust it came, had a "thick" part that was nearly twice as long as the one now. I felt as if the bike had a little more power with the new exhaust, but not for long. It ran super rich and I changed the plug every 50 miles or so. Chuck started re-jetting the carb and playing with the airflow screw. I honestly feel that the bike never really ran right. It's still running rich even at 1.5 turns counterclockwise from all the way in on the air flow screw.
The engine is pinging a lot and consistently, sometimes louder than other times. I read this is normal but my gut tells me that this is excessive.
I lost power at the top end and can't really get over 65mph, and it takes a while to climb from 60 to 65, that wasn't the case before. I don't need to go any faster than 65 really but it is a difference from how it once behaved.
I  have close to 6000 miles on the bike now. The oil has been changed and the clutch cable replaced and about 20 plugs. The guy that changed the oil said he also tuned it but it felt no different. He actually overfilled the oil and it started blowing out I believe the big, original air filter box if I remember correctly. It was a mess. He re routed some hose to the other side and now it spills out every once in a while, seemingly when I ride a little more aggressive.
Hopefully you're still with me ;) There's more minor things but I'll address those once I have this bike running properly again.
Yesterday I watched a video on tuning, setting the points and the timing with a special tool from nfieldgear, I ordered the tool today. What do I need to be able to turn the engine with the bike off? A hoist, is there a particular piece of equipment that is made for this? Of course there is, I guess I'm asking what it's called.
My father is a mechanic and I worked with him for 2 years in my teens, so I am handy with tools but I really don't know the first thing about bikes. I am determined to learn, especially since I can't find a RE dealer in Baton Rouge, and I'll be here for a year at least.
So, any and all help is appreciated in regards to any and all issues above.
This was a little long winded but I figured I'll give it a shot.
Thank you for welcoming me to the forum as well, I appreciate it ;)
Samir
Reply #1 on: June 30, 2013, 06:03:15 pm
Okay, well the bike you have is a model with the AVL engine, and there is a section for the AVL bikes just below this section.
That is where you'll find people who have bikes with that engine and can address the issues you have with the carb and other aspects.
I really don't have experience with that CV carb or its tuning, but it sounds like your bike needs a lot of "sorting  out".
Reply #2 on: June 30, 2013, 06:04:55 pm
Have you ever tried draining the gas tank and carb, replacing the fuel filters and topping off with some fresh gas and a splash of SeaFoam?  To me it almost sounds like very poor quality fuel or even some water in the fuel.
Sounds like you are on the right track tho.  Read and watch as much info as you can, particularly on setting up your carb.  It might be a timing issue, but it sounds fuel related to me.  I personally would drain every last drop of fuel out of your system, pull the carb completely apart and start hosing everything down (in/on the carb) with carb cleaner.  Make sure you put the spray tube in and shoot cleaner thru every orifice on the carb.  Se if that makes a difference or not and go from there.
Samir72
Reply #3 on: June 30, 2013, 07:07:46 pm
Thank you ace, thank you Scottie
Well, I learned one thing already, I have an AVL engine!
I reposted this in the appropriate forum :)
Samir
  • Global Moderator
Reply #4 on: June 30, 2013, 10:20:55 pm
The AVL engine you have is a good engine. I agree that with a bit of "sorting out" you will be in good shape.
www.cyclesidecar.com
Reply #5 on: June 30, 2013, 11:31:32 pm
I gave you my thoughts in the new post located in the AVL forum.
Samir72
Reply #6 on: July 01, 2013, 04:11:08 am
Scottie, thank you.
I got some Seafoam and added some to the tank.
I'll take your advise and empty the tank etc when I get back from traveling in a week or so.
Thanks,
Samir
