Snow Balling
October 06, 2015, 07:49:40 pm
Author Topic: Luggage rack/pillion seat  (Read 4280 times)
« on: June 11, 2008, 06:51:11 am »
Be aware that the luggage rack/pillion seat in the catalogue is not a direct bolt on for the Military.  At least it wasn't on mine.  The wider rear fender left no room for the nuts that hold the new shock mounting bolts.  I spread the legs of the rack and cut new spacers out of conduit  to get things to fit.  A small spacer was needed on the outboard side to give room for the nut on the inboard side and then a shorter spacer than what was provided to support the rack.
Re: Luggage rack/pillion seat
« Reply #1 on: July 09, 2008, 12:12:21 am »
I added the carrier rack with pillion seat and like it very much. The carrier was very straight forward to install. HOWEVER, the seat is another matter. Instructions not included and I wish I could help explain how it fit on but I eventually went to the hardware store and purchased  4 copper plumbing brackets and stainless nuts and bolts. A pair for each bracket. Took the cover off, drilled through the padding and through the base. reattached the cover and then bolted the seat to the carrier before reinstalling the carrier to the bike.
  • Yeah I stepped in it.
« Reply #2 on: May 23, 2012, 10:14:08 pm »
does any one have pics of how they mounted it to a C5 military?
