Awright! Nice to finder another RE guy here in NM. I'm betting yours was the one in the crate out back when I picked up mine.
I'm in Albuquerque and got mine from Richard in SF, too. 2012 C5 Classic Special. You're gonna love this bike, and these forums are invaluable. In fact you find just as much and more info here than you will in the service manuals.
Listen to these folks!
+1!---Like bare said, changing to a BPR6ES ($2-3) or BPR6EIX Iridium ($7-11) plug will make a helluva difference in your idle and you'll note better response with your throttle, too. Best prices are at O'Reilly's. The Iridium will run about $7. Excellent investment.
+1---I've put about 600 miles on mine and had to adjust the OEM chain twice already. My Tsubaki from NFG arrived this week and I'm swapping them out tomorrow along with pulling the chain case and checking the primary chain and sprockets.
---Unless you actually
like the bazooka silencer, ditch it for freer-flowing unit. The OEM unit is very restrictive due to the 3-stage cat. I got the Reverse Meg from NFG. Others have gone with the EFI silencer. Either way you'll gain a few HP and look more, uh, "classicky".
+1---Blue Loctite! Use it or lose 'em! I heard something go through my front spokes on the honeymoon ride home. It was the nut for the Speedo cable retainer on the front fender. Been through most of the bike now and so far no further losses. Double-check the cylinder head-to-frame stay and snug it up.
---Be wary of any torque values given in the Owners' or Service manuals, IE the plug torque given is WAY to high for a plug in an aluminum head.
---If you haven't already, get your fork oil changed to get rid of the crap they use at the factory.
