Author Topic: Gday from Canberra, Australia  (Read 2435 times)
Dudefella
Reply #15 on: June 28, 2013, 05:08:15 am
Thanks fellas! With a bit of luck my bike will arrive on my doorstep next Thursday. Already got a new seat and saddlebags waiting for it, and I'm going to go source the correct NGK iridium sparkie on the weekend - I think its coded BR8EIX
« Last Edit: June 28, 2013, 05:16:47 am by Dudefella »
Reply #16 on: June 29, 2013, 12:17:28 am
As you know, we suggest using the NGK BPR6ES plug.
The 8 in your spark plug number indicates that spark plug is "colder" than the 6  we are using on the fuel injected UCE.
NGK temperature numbers are somewhat backward from other companies.  Low numbers are hot and  high numbers are cold so the tip of a #2 would run very hot and a #9 would run very cold.
The colder #8 you have found may develop carbon buildup on its center electrode even though the engines fuel/air ratio is correct.  The carbon buildup can cause fouling problems.
As you mention,  your spark plug is a iridium plug and it will probably set you back a bunch of dollars.
Although the RE engine has been updated with hydraulic valve lifters and a automatic compression release it still is an old fashioned, low reving, OHV pushrod engine that works just fine with a standard old fashioned spark plug like the NGK BPR6ES that only costs a couple of dollars..  No need for a expensive spark plug with this engine.
For the price of one iridium plug you could buy 3 standard plugs so you would have 2 spares if you ever need them.  :)
« Last Edit: June 29, 2013, 12:19:37 am by Arizoni »
wildbill
Reply #17 on: June 29, 2013, 02:09:12 am
just pulled mine  :-[ :P-correction-removed the spark plug.
iridium bpr6eix 8)
Dudefella
Reply #18 on: June 29, 2013, 06:04:40 am
Thanks chaps!
That reminds me - does the RE toolkit come with a spark plug removal wrench tool?
wildbill
Reply #19 on: June 29, 2013, 09:55:47 am
sure does
D the D
Reply #20 on: June 29, 2013, 04:30:48 pm
Don't know if they changed kits over the years but it should be a tube wrench that one end does plugs and the other does the big wheel nut.  You use the Jimmybar with it. Crude, but fine for the road.
1975 XLCH
Reply #21 on: June 29, 2013, 06:40:32 pm
No wheel end on mine, just the plug end. The wheel one wouldn't fit in the cheesy toolbox (hot dog warmer) of a G5
