Bullet 350 DLX
41 Guests, 3 Users
wildbill, malky, mattsz
May 31, 2016, 05:09:42 am
Author Topic: Primary Cover Repair  (Read 3618 times)
Re: Primary Cover Repair
« Reply #15 on: June 30, 2013, 07:59:35 pm »
I think I'm going to run diesel fuel in my primary.    ;D
I just may try the ATF, but then again, if the damn thing still leaks after new seals and gaskets, I'm just going to let the damn thing leak.  It's not like I've ever owned anything that hasn't leaked.   ;)
AgentX
« Reply #16 on: June 30, 2013, 11:01:26 pm »
Scotty, if you're thinking of the bike I'm thinking of that had the stock clutch running exposed, I'd note that the whole bike was more of an art project than a real riding machine.  Might not be best to take mechanical cues from that sort of thing.  I know someone who handled it in person and he had reservations about a lot of the actual workings, including the stock clutch running dry and exposed.
For what it's worth, Hitchcock (and maybe Newby direct, which is cheaper) sells the Newby dry clutch to run with the duplex primary chain.  Cheaper than the full belt setup, but I don't know by how much.
I'm going to use the belt unit on my Fireball.  When I asked Newby how often to grease the bearings, he replied:
"We donít have a specific mileage interval, some of our customers leave it for years, while others must get bored and do it regularly.  On my race bikes we strip them every season but my road bikes tend to get neglected.  I think most people tend to work on the ďIf itís not broke donít fix itĒ principle. Probably not the best approach !
If you want to check that it turns freely without any dry rough feeling when you rotate the centre with the plates removed. We can send you some of the correct synthetic grease if you want to have a go yourself. If you just want enough for the clutch bearing itís foc, or a tub is £5 inc post and vat.  Itís best to have 3 screws for the alloy back plate in case you damage them . They are Loctited so may require heating to release. We can include these with the tub of grease.
Best regards,
Bob."
« Reply #17 on: June 30, 2013, 11:31:21 pm »
Oooooooohhh, Belt Drive.....    ;D  Tell me more AgentX.  I'm very curious about that set up.
AgentX
« Reply #18 on: July 01, 2013, 12:26:59 am »
Ummm...it's expensive, Ace and Chumma both like it, and it's cheaper from Newby direct than it is from the big H.
That's all I know right now!  I'm using it to cut down on drivetrain losses, cut down noise, and because I really hate opening up a wet primary.  Regreasing the clutch hub once a year I can deal with, especially since I won't have to deal with an ATF bath when I do.
I know now that my rebuilt bike will have a reliable charging system that I won't open the primary much, but as far as I'm concerned, I've dealt with enough ATF spew my life already.  (My 350 had alternator issues, then needed the primary cases replaced...what a pain...had that thing opened what feels like a million times in the dark carport at midnight, being chomped by mosquitos)  One less seal to maintain, one less fluid to change.  Works for me. This bike will be an exercise in indulgence.
Edit:  Oh, and I've had grief from primary tensioners which would or would not fit various cases, and a stripped stud for the tensioner, etc.  The belt eliminates the tensioner, which is another "whoo-wee" moment for me.
I know it's not an issue for anyone who's never had an issue, but for me there's value in that.  One less (potentially) moving part!
« Last Edit: July 01, 2013, 12:35:31 am by AgentX »
« Reply #19 on: July 01, 2013, 07:41:07 am »
Do they make a Newby for a RE twin?  ERC
« Reply #20 on: July 01, 2013, 09:22:15 am »
« Reply #21 on: July 01, 2013, 12:35:31 pm »
That's interesting thanks. May try one on my next project.  ERC
« Reply #22 on: July 01, 2013, 12:41:47 pm »
I'm definitely going to be sending them an email.  So is it an exposed belt drive or is it enclosed by the primary covers still?
« Reply #23 on: July 01, 2013, 01:13:24 pm »
There's usually some sort of modified Primary Cover for safety that's partly open/vented for air cooling the clutch.  They probably leave that to you to make up.  Though I've seen people with Harleys running them open to show off.  They'll get something like a stick or pant leg in there someday.
AgentX
« Reply #24 on: July 01, 2013, 08:34:49 pm »
Far as I know, it's meant to be run enclosed.  Chuck D has one and Chumma put stylin' screened-over vents into the outer clover from what I saw on Flickr.
I can't imagine it'll implode into a singularity if you run it open, but grit between clutch plates and in the belt teeth seems inevitable and detrimental...
