MY RIDE
May 31, 2016, 01:09:06 pm
Author Topic: Chain slipping  (Read 2823 times)
Re: Chain slipping
« Reply #15 on: June 23, 2013, 06:58:09 pm »
I'm very glad to hear you made it home. :)
As we were all cussing and discussing your problems I kept wondering, "Where's Rich?  He should have been back by now unless he's picking up pieces of his chain from the roadway behind him and trying to stick them back together."  ;D
Sectorsteve
Re: Chain slipping
« Reply #16 on: June 24, 2013, 12:52:40 am »
Id be interested to know what you pay for the new sprocket and chain.
I was told after my new sprocket was installed that id need to adjust it after 200kms. That was bollocks. Ive done about 3000 since then and the slack/tension is right. Unsure of what new chain ive got. the dealer wouldnt tell me - except that "its a better chain" It def seems to be a better chain, but as he wouldnt tell me, i have no idea what it is.
hortoncode3
Re: Chain slipping
« Reply #17 on: June 24, 2013, 07:41:26 am »
Unfortunately I have been in this position. Too much wear on a crappy RE chain equals chain slip, shearing off the tips of the sprockets. $300 worth of sprockets and labor and a $100 O-ring chain..and I'm MUCH happier.
Re: Chain slipping
« Reply #18 on: June 24, 2013, 09:08:24 am »
I got sprockets recently: $70 for the front, $75 for the rear plus the chain.  On my last bike it was very easy to change the sprockets, the RE is a bear by comparison.  Not terribly difficult, just a pain.  The right side engine cover needs to come off and you need to remove a 46mm nut in the front.  In the rear, you need to remove the brake assembly.  Have a manual handy if you go at it with your maintenance buddies.
« Last Edit: June 24, 2013, 12:45:21 pm by Ducati Scotty »
Rich Mintz
  • Daily rider in the city
Re: Chain slipping
« Reply #19 on: July 26, 2013, 04:30:19 pm »
My bike is ready! I'm getting it back next week. New sprockets and chain, routine maintenance, and they fixed my transmission problem under warranty. If I understood them on the phone correctly, the pin that came out in my oil was not the problem -- instead, one of the nuts and bolts holding the clutch assembly together had fallen out.
Thanks, Kevin (if you're listening), for hooking me up with a reputable and competent dealer.
Rich Mintz - New York City
richmintz@richmintz.com
[/URL]
Re: Chain slipping
« Reply #20 on: July 26, 2013, 05:22:51 pm »
Good deal!    :)
Re: Chain slipping
« Reply #21 on: July 26, 2013, 05:34:38 pm »
Good news, Rich!  Gosh, I'm sure wondering now, what was that pin?  I hope they sorted that one out, too!
BTW, don't worry, Kevin is listening...
Rich Mintz
Re: Chain slipping
« Reply #22 on: July 26, 2013, 07:30:35 pm »
They looked all through the transmission and bearings and couldn't find a pin missing. (I'd given them the actual pin I found.). So it's still a mystery. Some things aren't meant to be known!
[/URL]
ROVERMAN
Re: Chain slipping
« Reply #23 on: July 27, 2013, 01:44:39 pm »
Oh Rich, you have no idea how funny and how common this is. Well, funny now you have it sorted!
Robert & REnfield. 8) 8) 8)
Re: Chain slipping
« Reply #24 on: July 28, 2013, 07:13:18 pm »
Glad you're sorted and that you'll be back on the road soon.  Glad you've got a reputable dealer now too :)
Rich Mintz
Re: Chain slipping
« Reply #25 on: July 31, 2013, 12:02:51 pm »
Alas, it was not to be. Turns out my shifting problem was reduced, but not eliminated -- bike shifts very smoothly but still won't shift below second gear. So dealer is holding onto the bike for a couple more weeks, and I'm on the train back to NYC with my helmet under my arm.
http://instagram.com/p/ccB_AWJriY/
[/URL]
Re: Chain slipping
« Reply #26 on: July 31, 2013, 12:26:08 pm »
Ask the shop to call CMW directly.  The staff can point them to likely causes and maybe save them some time and headache.  Sorry you're off the road again :(
