Jon's deluxe
February 13, 2016, 05:52:30 pm
Author Topic: fork oil  (Read 1213 times)
no bs
fork oil
« on: June 18, 2013, 10:41:15 pm »
any recommendations? i've used atf in honda forks, and how much in each leg?
Re: fork oil
« Reply #1 on: June 18, 2013, 10:45:21 pm »
You didn't say which RE you were working on but about 160-180cc should be about right for most of them.
(I'm sure if I'm wrong, someone will jump in and give us their answer. ) :)
Re: fork oil
« Reply #2 on: June 18, 2013, 11:50:26 pm »
I find ATF too light and proper fork oil smoother.  I've got Torco 15 weight in mine which might be too light for some folks.  I'm 170lbs in pothole city and started with ATF "F", then 10w Amsoil Medium, and then went up to 15w Torco.  BelRay 20 weight or PJ1 is quite popular.  Any of the major brands are decent oils; Castrol, Motul, or Silkolene for instance.  It's just finding the weight that works for you in the brand you can get and/or prefer.  Honda dealers here carry BelRay and PJ1.  But anything over 10 is hard to find locally these days.
200cc in each of my forks per the manual, but that's an '07 old style.  As Arizoni says, newer bikes are 180cc from what I read.
no bs
Re: fork oil
« Reply #3 on: June 19, 2013, 10:36:43 am »
2011 g5. thanks!
Re: fork oil
« Reply #4 on: June 19, 2013, 02:33:14 pm »
I used Maxima 10W fork oil in my G5, 200 ml. Worked great! I used maxima because that's what the guy that I bought the oil from was selling. I have used most of the other brands, particularly BelRay, and they all work fine. ATF is and old wive's tale from the '50s before they made specific fork oil and everyone was using 30wt engine oil. Forget those days. Real fork oil, oddly enough, works very well in forks! No need to use any other witches' brews!
« Last Edit: June 20, 2013, 11:02:52 am by barenekd »
Re: fork oil
« Reply #5 on: June 19, 2013, 05:24:48 pm »
Speaking of witches brew, ..I might mix half ATF-F and 30w oil to try and get a better ride.
Found some fork oil,  7w and cost $18.
Re: fork oil
« Reply #6 on: June 19, 2013, 07:38:52 pm »
Fork oil + shipping can be ordered online for less than that. And witches brew is usually why witches have warts.
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
Re: fork oil
« Reply #7 on: June 20, 2013, 10:20:56 am »
I used some Amsoil synthetic ATF I already had, & am totally satisfied with my forks function.
Best Wishes, Craig McClure
63falconht
Re: fork oil
« Reply #8 on: June 20, 2013, 06:49:11 pm »
30wt oil, rides like completely different bike.
heloego
Re: fork oil
« Reply #9 on: June 20, 2013, 09:15:32 pm »
My dealer and I went the rounds about fork oil when my bike arrived. I requested the oil be changed and 10W used. He's actually a scooter guy and insisted on at least 15W-50. In the excitement of getting my bike, and not in the mood to start a fight I relented and went with the 15W.
Unless it's gonna have an adverse effect on my fork seals, so far I'm happy with the ride.
Re: fork oil
« Reply #10 on: June 20, 2013, 10:40:32 pm »
Its very easy to change ,...at lest on the  Old Classic frame.
hortoncode3
Re: fork oil
« Reply #11 on: June 25, 2013, 08:40:26 am »
I've been happy with the stock oil, but for my information..when should I change it?
Re: fork oil
« Reply #12 on: June 25, 2013, 10:51:24 am »
You won't be happy with it when you see what comes out!
My manual says check at 3k miles and Replace at 6k miles.  I changed at 3k miles and love the improvement over the black and gray factory sludge.
Re: fork oil
« Reply #13 on: June 25, 2013, 02:26:43 pm »
Yesterday. This is one of those things that should be done when you bring the bike home!
You'll be a lot happier when you find that the forks actually move!
heloego
Re: fork oil
« Reply #14 on: June 27, 2013, 09:44:03 am »
+1!   :D
